Home | RCA | DRC247N DVD Player | Can not find disk
RCA DRC247N DVD Player
Problem for RCA DRC247N DVD Player
Can not find disk
By darevjld on May 03, 2009
it was working fine until it became unplugged
now it say it can not find disk
it plays a audio cd but not a dvd movie
it is a rca dr247n
Solution #1
posted on Nov 05, 2009
Not Rated)
faxdaddy
Rank: Apprentice
Rating: 0%, 0 votes
Here is what I did and it has worked ever since.
I'm not a DVD tech, but I'm a career printer technician so I understand electro-mechanical devices.
Symptom: "Loading" for about two minutes before "no disc"
This adjustment is very delicate. Be gentle and patient.
The issue (on mine at least) was that the (I don't know what to call it) "platform" that the dvd rides on had slid down the shaft and was rubbing aganst the motor housing. This was keeping the DVD from spinning up to the correct speed. I VERY GENTLY took a small prying device (the blade of my pocket knife) and pryed this "platform" back up the shaft just a hair. You pry a bit, then you turn it half way around and pry again, and you keep this up for four or five times. (Did I mention GENTLY?) It doesn't have to go far, just a fraction of a millimeter. Just enought to keep it from rubbing the motor housing.
It's not a permanent fix because after a while it will get worked back down the shaft by that monster weight that rides on top of the dvd. Not real sure why that thing is even there, but I left mine in. Some have mentioned taking them out. As a more permanent solution, I'm thinking about putting a micro drop of superglue on the end of that shaft to stop the slide.
I hope this helps!
Dave
Fairway Laptop Service
Bentonville, Arkansas - Home of Wal-Mart!
Was this helpful?
Yes
No
Popular Solutions for RCA DRC247N DVD Player
Questions and Unsolved Problems for RCA DRC247N DVD Player
Do you recommend RCA DRC247N DVD Player?
Answer
Answer
how do i take off the progressive scan after i enabled it and now my screen is un recognizable. i... (More)
Answer
My dvd player is starting to freeze up while playing a dvd. Is there anything I can do to correct... (More)
Answer
I am unable to play my burnt DVD-R in my RCA player. What can I do?
Answer
i was putting in code for new remote when the screen started flicking vertically and does'nt stop.... (More)
Answer
I have hooked up by DVR using component cables to a Samsung LN32B360 tv and the picture when I view... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA DRC247N DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
