Televison & Video Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dark screen!!! Bratz 15"LCD1510DB TV-DVD COMBO
HI my lcd just turn dark in menu brightness, contrast set up as always but hue setting just blank space?????? pls help
Anonymous
Level 3:
President:
  • Master 1,779 Answers
  • Posted on May 03, 2009
Anonymous
Master
Level 3:
President:
Answers
1779
Questions
Helped
578622
Points
5452
That's your main board, they can cost as much as $350.00 some a little less.
My screen for teac lcd tv/DVD combo lcd1001m has gone dark, is there a way to fix this
If the screen for your TEAC LCD TV/DVD combo has gone dark, there are a few things you can try to fix it:
  1. Check the brightness settings: Make sure that the brightness setting on the TV is not turned all the way down. This can happen accidentally, and adjusting the setting may solve the problem.
  2. Check the power supply: If the TV is not receiving enough power, the screen may not light up properly. Make sure the power cord is plugged in securely and try using a different outlet.
  3. Check the connections: Check all the cables and connections between the TV and any other devices. Make sure they are plugged in correctly and that there are no loose connections.
  4. Reset the TV: Try resetting the TV to its factory settings. Consult the user manual for instructions on how to do this.
If none of these solutions work, there may be a hardware problem with the TV and it may need to be repaired or replaced.
2answers
Too dark
well...the contrast comes to mind first, and then the color temperature..it's all accessible from the menu, of course.
I'd start with contrast, and then look at the color temperature ratings..
Screen is too dark
try turning up CONTRAST or COLOR or TINT or HUE hope this helped..... how bright is the room is the tv easier to see at night if the sun is hitting the screen that will make a big difference..
How to adjust brightness
The set should have in the on screen customer menu settings for brightness, contrast, color, tint etc.
If in doubt consult the owner manual which will have instructions.
3helpful
The remote does not work and the tv will not accept an universal remote.How can I adjust the color, brightness, contrast, and etc. with out a remote. The screen is dark and can not be adjusted without a...
Tries press the tv menu button on the tv front frame bazel to select color,brightness,contract so on...Adjust ur setting.Try website like remotes.com to buy an a exact to the original remote.
Dark screen!!!
do a system restore
2helpful
SANYO DARK SCREEN
Did you goto the MENU to access the different controls ?
Brightness, contrast, color, tint hue ??
There is always a way without the remote control [R/C] to get at these controls.
2answers
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
1helpful
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
