Question about Philips 32PT5441/37 32" TV
Tv wont come on
Off and on button keeps flicking,I think it is somthing on the remote control.in the QuadraSurf buttons or sleep mode button I get no picture or sound.
    Genius:
  • 1,694 Answers
Rebuild with upgrade kit #483531057673.
Posted on Oct 05, 2007
Philips quadrasurf TV
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
Sep 08, 2014 | Philips 40MF430B/F7 model Magnavox LCD TV,...
How to program my quadra surf remote to hitatchi television
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 15, 2012 | Thomson 14MG135 14" TV
Toshiba 61PJ7UA, turn itself off and will not start. Power on light is red but when you hit the remote to turn TV on it clicks but dosent turn on(no green light). I have the circuit boards (particularly...
HERE'S THE ANSWER TO YOUR PROBLEM:
I think the problem has nothing to do with your TV. I bet the culprit lies on the setting of your remote control. Maybe you set your remote into a sleep mode. When a TV has set into a sleep mode. It's power on light is still red but doesn't work. So all you've got to do is keep pressing the sleep button. After a few presses, it will definitely work. And, you can now enjoy your day watching TV. Thanks.
Jul 10, 2011 | Televison & Video
What is the remote access code for a sanyo DS24205?
Normally all sanyo kits have two remote acces codes. One is Press Sleep Button on the remote handet and Menu button on the front panel of the TV simoultaneously.
Second is a tricky one.
Press Volume+/Vol_ to set the volume level to zero and press 'REP' on the remote control hanset aln loosen.
Keep pressing Vol+/Vol_ on the unit and press 'REP' on the remote control again.
Factory status will be displayed.
This is the service mode. You can adjust the parameters with the help of programe and volume control buttons.
To exit from the service mode, do the above said three again, unless the chaged parameters will not be stored in memory.
Another method is, if the hanset has a hidden key, usually at the lower side, which seems as a small hole. press it with a small stick to fit, may enter to remote code options.
Oct 13, 2010 | Sanyo DS24205 24" TV
Need codes for Philips QuadraSurf TV remote
tv code for toshiba tv using Philips QuadraSurf TV Remote # RC1903600
Sep 16, 2009 | Philips Universal PH301S Remote Control
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
MAGNAVOX PR1910 C125
try pushing the up volume button and the down volume button at the same time.
Jan 03, 2009 | Philips 28PW6506 28" TV
Remote controler
press picture/sleep button. use the buttons on lower left to set. press arrow bouttons to set time and hit enter (middle button)
Jul 05, 2008 | Philips Magnavox 20MS233S 20" TV
Philips 32PT5441/37 32" TV Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
