Question about Philips 43P8341 43" Rear Projection Television
Phillips 43p8341 tv keep shutting off
My tv keeps shutting off and now it won't turn back on at all it's been off for 2 weeks now and I tried to turn back and still won't turn back on I also left it unplugged help me please
  • 2,920 Answers
Re: phillips 43p8341 tv keep shutting off
Some of the parts you can find online some you aounds more like the power supply than anything else
Posted on Oct 26, 2008
0 characters
3 Points
TV shutting down, lamp and power light blinking
I would try a new lamp. Lamps have varying qualities & usage conditions may cause varying life spans.So, even though the lamp may be 1 year old I would try a new one first.
Jan 07, 2015 | Samsung HL61A650C Television
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Projection Televisions
The TV keeps shutting off, then shortly after turns back on, then shuts off again... Plugging the cord into a different wall outlet doesn't solve the problem. Please help! Thank you
I'm having the same problem. My TV will play for for awhile and then it just dims down for about 1 to 2 minutes then powers up again. The green light stays on doesn't blink at all, and there is no red light that comes on or blinks like when our lamp went out. We replaced the lamp about 6 months ago and it's been working great until this week.
Oct 25, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Philips 43P8341 will not turn on
sounds like your two convergence ICs are shorted out, plus you probably need two 6.8ohm resistors ICs are part # STK392-120
should be installed by a trained repairman cost about $300-400
Aug 17, 2009 | Philips 43P8341 43" Rear Projection...
Our tv made a loud high pitched noise for a few weeks and then the color went green to then shutting off. Now, when we try to turn on the tv, the light blinks and then it just shuts off and keeps repeating...
Hi, Symptom shows high pitch sound is of color wheel that is not spinning any more so TV stay in protection mode and does not power up. TV requires color wheel replacement.
Jun 15, 2009 | Samsung HLN5065W 50" Rear Projection...
Phillips 43P8341 no picture, blinking red light
Goto They have a kit that will fix this common problem.
May 17, 2008 | Philips 43P8341 43" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
155 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
