Question about SanDisk Sansa e260 MP3 Player
Puting playlists on my sansa
I cant get my sansa to play playlists that i have put on it. I've tried putting it directly into the sansa using MSC mode and using windows media player 10 to SYNC the lict with the sansa. nothing i have tried works Help!
  • 626 Answers
You have to set the playlists to auto-sync with the device. That is the only way they work with WMP 10. Best of Luck.
Posted on Oct 06, 2007
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
Converting videos on to my sana fuze
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USBmode located on the sansa if asked to change to MSC goto menu pressenter scroll to settings press enter scroll to usb mode press enterscroll to msc press enter press menu.....Connect should auto startsansa software..... Sansa software/driver Updates firmware followinstructions Downloads manual Downloads converter
Dec 31, 2009 | SanDisk Sansa Fuze MP3 Player
I have a sansa view 16 gb mp3 player in the MSC mode, I can not see Play List when viewing my sansa player in windows media player. (system - XP)
play list is a file that just save the property of songs of that particular software, make sure once you save the play list it can be recognize by your mp3 player, some player generate their own playlist, and makesure that the songs that was in your playlist is also in your mp3 player.
Sep 28, 2009 | Audio Players & Recorders
I can't delete songs from my Mp3.
I had the same problem.
On the MP3, go setting and then to USB.
There are two options: Auto Detect or MSC. One will be checked showing the current connection type. Select the other one and connect the Sansa to your computer.
For some reason, the Sansa doesn't recognize files loaded in MSC if you're connected in Auto mode and vis versa.
In MSC mode, it will show up as a devise with a drive letter. In Auto mode, there's no drive letter; it shows up as a removable devise.
Also note, you can only add Playlists in the Auto mode. MSC mode does not recognize Playlists or if it does, I haven't figured out how to do it
Dec 08, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Sansa 200
Songs are in the wrong format
Dec 19, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Playlist Problem !!!
The Sansa m200 series can only create playlists in MTP mode. on the menu go to settings>USB. There are two options MSC and autodetect. Once in autodetect your sansa should say MTP when connected to your PC. In this mode you should be able to add playlists without any trouble.
Hope it helps
Nov 23, 2007 | SanDisk Sansa m240 MP3 Player
Duplicating songs
The device has 2 modes of operation MSC and MTP.
If you put music or playlists on in either mode and then changed modes to add more music, you will inevitably have duplicated your music.
Best solution is to format the device to remove everything, then pick one mode ant use that one only.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa E280 MP3 Player
Song problem (SanDisk 4gb
This is going to take some investigation on your part. First of all, make sure that the correct song works on your PC. That is, if you launch Don't Wanna Miss A Thing on your PC and Bout It plays, then it's the media file, not the Sansa player. Make sure you launch the specific media file from Windows, NOT from your media player software. You want to check the FILE first. (Reverse the files too - launch Bout It and see what plays) If the files are right, then launch them from your media player software. If they're wrong when you play them from the media player software, check the properties of the song. If everything is okay on the PC, then check the Sansa. If you are directly launching the music file on the Sansa (that is, not from a playlist) and it's wrong, then put the Sansa in MSC mode and check the file. Drag it to your PC and launch it. If it's wrong, replace it. If your launching the file from a playlist, just redo the playlist with the correct file after you've finished your troubleshooting.
Jul 12, 2007 | SanDisk Sansa e260 MP3 Player
Problem puting songs on
The MAC reformatted the player, and eliminated the formatting that contained the music songs - this player had a dual mode system where it could either function as an MSC device or an MTP - the manufacturer placed Recordings and Radio on one mode, and music files on the other. A PC can recognize both sides. Macintosh cannot. This player is not MAC-compatible.
Jul 16, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
99 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
