Question about ClearOne Communications Max Wireless (910158001) Audio Conference
Display shows "Not Registered"
Display shoes "Not Registered" On model 910-158-030 Rev 4.1
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Posted on Nov 28, 2007
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
9. UNPLUG THE HANDSET BATTERY
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual if you need it.
Mar 14, 2016 | Lands Phones
6520 rev hh
check red 4 pin connectors to see if any wires touching if not make sure wires are tight also make sure wire isnt cut or knicked sometimes landscapers do it not knowing seems like shorted wire if you can take controller with shorter wire and try next to aqualink if it works bad wire if not bad controller
May 01, 2013 | Jandy Aqualink RS6 Pool Only/Spa Only...
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
I have a GE model 2810GE AND THE screen say's HAND SET NEEDS REGESTRATION. WHAT SHOULD I DO ? CHARLES
This is from the instructions at GE's site for the model 28110 (you said 2810, which isn't found):
  1. Press the mute/program button. Hold BASE PAGE for 5 seconds, then PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.)
  2. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number
Hope this helps. Thanks for using Fixya!
Feb 11, 2010 | Uniden Cordless Phone
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
ClearOne Communications Max Wireless (910158001) Audio Conference Logo
756 people viewed this question
Top ClearOne Communications Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a ClearOne Communications Lands Phone Expert? Answer questions, earn points and help others
