I think it isn't fine because if a fridge/freezer that is otherwise healthy runs continuously (due to a thermostat fault), it would be colder than you could imagine with lower than arctic temperatures in the freezer compartment, minus 30-40 C for example.
The conclusion must be your fridge isn't fine.
Proper freezer temperature, incidentally, is minus 25-27 C for food to have a reasonable lifespan with minimal deterioration. There is no benefit from being colder but significantly warmer would mean the freezer contents should be replaced much more often - the freezer compartment of an old fashioned fridge (about minus 5) was reckoned to give fish, meat and dairy up to one month safe lifespan.
A fridge that runs continuously (where the thermostat is good) could have a refrigerant loss resulting in a huge drop in efficiency, the insulation could be failing, the compressor could be failing or the de-icing panel could be permanently switched on - or any combination of these things.
I note you say the coils are clean. If the refrigeration system is good with the compressor running continuously the coils will be hand-hot.
This information is usually readily available direct from the MANUFACTURER and/or ON-LINE. If you don't have access to a computer just see your local store or give the manufacture a quick call ...
Montgomery ward refrigerator product support information from ManualsOnline.com. Find montgomery ward refrigerator user manuals, instructions, and free ...
Does the freezer get cold? Any cooling? There could be a number of things. Biggest problem is this machine is not worth fixing. The amount of energy it uses monthly is probably 1.5 times what a new one uses in a whole year. Technology has changed greatly in the last 42 years. Recycle your old one. Some utilities, like the one in my area, will pay you to replace it!!
First of all I'll need to know about how old it is and second where is the fan located ie. on the rear wall or on the bottom of the freezer compartment?
ur solving ur own problem the fan either needs to be thawed ,lubed,repaired or replaced the fan uses the air from the freezer to cool the fridge side but bench test the fan before replacing if fan good than check the thermostat in fridge for proper working order
I am not sure if know what you are talking about,but if this like a refrigrate,then I would check under the bottom to see if the condsener is clogged.Check to see if the fan is running.
