Question about RCA F31672ET TV
RCA F36676ETFM2
Tv works fine for 15 minutes then I get no sound or pic just ant races. Hooked to antenna it works fine. Just losses it when hooked to cable or satelite.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It sounds me that it is due to cable wire connection where it is connected is probably might be loose or if you have cable box there is some loose connection.
Posted on Oct 05, 2007
SOURCE:
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
I cannot get regular tv to come in and my antenna is hooked up properly
Here is a few suggestions:
1) Make sure the tv's vide mode is in "TV" or "ANT" or "Antenna" some times even referred as "Off Air"
2) In the TV's settings make sure a "Channel Scan" has been performed to tell the TV which channels are available in your area. If this is not done you won't be able to select any channels. Also make sure that the antenna is of the right impedance (i.e. 52ohms) check your manual and see what your TV accepts.
3) Make sure that you are using coxial cable connection and not RCA or HDMI connections as these connections are not designed for an over the air antenna.
Mar 02, 2011 | Sanyo 42 in. LCD TV
We have a Model # 50GX49B 50" inch TV, That our
You need to set the antenna input back to ANT A (1), you are ANT B (2) right now that why you are not seeing any signals.
Use the INPUT button on the remote to scroll through until you see ANT A which is the one your kid use for the cable connection,
You should download this user manual:
http://www.retrevo.com/support/Hitachi-50GX49B-TVs-manual/id/371bh845/t/2/
Let me know if it works.
Dec 31, 2010 | Hitachi 50GX49B 50" Rear Projection...
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
My new tv digital converter box weill not pass analog tv signals. The tv works fine if I take the box out of the circuit. I am in a motorhome using the normal tv antenna on the roof.
you need to split ant. signal then get a manual selector switch hook 1 wire to convertor input then the output& the other ant wire to the selector switch then from selector to tv
Dec 20, 2008 | RCA Televison & Video
RCA DRC8030N
That sounds about right if you have cable instead of an antenna cable. If it can't tune anything but 5 channels in, that's all it claims; set it to CABLE IN instead and try that so the tuner can get along with your cable box. If you really do have an antenna hooked up, get it away from whatever's reflecting signal and screwing up reception.
Sep 12, 2008 | RCA DRC8030N
Televison & Video Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
