Question about Dell Inspiron 4000 Notebook
Inspiron 4000 black screen
I changed themes and the computer now comes on with an all black screen with icons barely visible. If you open anything you cant see but spots of it. I can't get into any program to change anything. Even in last good start and safe start it comes up this way.
  • Anonymous Nov 09, 2007
    i have the same problem with the dell d800 latitude, was playing a dvd suddenly the screen went dark black, can just sea all my icons but unable to get normal screen ??.
    john
  • Anonymous Nov 13, 2007
    Had the same problem with my Dell Inspiron 4000. Bought a new flex cable and inverter board on ebay.....works great. If that does not solve your problem then the backlight is bad.
    Sergeant:
  • 457 Answers
Try an external monitor if you can see that ecerything you created is as then your LCD is on the way out. I would then say its a coincidence it happened at the time you changed the theme.
Posted on Oct 05, 2007
  • Peter Hirawani
    Peter Hirawani Oct 05, 2007
    When in the external monitor try to change things back however if it still dont do it you may need to reinstall Windows but before you do come back here to see what happens with my suggestion and there is an alternate before installing again.
SOURCE:
Hp Pavilion DV-4000 Screen
Are you saying the lcd screen is black? It seems like it booted up but nothing appears on the screen?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 03, 2012 | HP Pavilion dv4000 Notebook
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
How to use a themes for my black berry
About themes Depending on your wireless service provider, you might be able to set a theme on your BlackBerry® device that changes how items such as applications, indicators, words, and icons appear. Themes might be preloaded on your device, or you might be able to download themes that are in .cod file format.
Switch themes
  1. From the Home screen, press the Menu key.
  2. Click Options.
  3. Click Theme Options.
  4. Click a theme.
  5. To change the layout of the theme, in the Set Home Screen Layout section, click an option.
  6. Click Save.
Delete a theme You can only delete themes that you have downloaded to your BlackBerry® device.
  1. On the Home screen or in a folder, click the Options icon.
  2. Click Theme.
  3. Highlight a theme.
  4. Press the Menu key.
  5. Click Delete.
Download a theme Depending on your wireless service provider, this feature might not be supported.
  2. Click Theme.
  3. Press the Menu key.
  4. Click Download Themes.
THEMES FOR UR MODEL
http://gallery.mobile9.com/c/blackberry-storm2+9550-themes_2570/1/
Jul 12, 2010 | RIM BlackBerry Storm2 9550 Smartphone
Black screen
yes, its the light. Its called screen bulb. The bulb is burnt, that's why the screen cannot be lighted up.
The solution is to take it for repairs. There is not settings or adjustment required.
Best regards.
Jan 14, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
yes your lucky thing is this problem is LCD CCFL lamp worn, change a new lamp should be fixed.
hwo to change CCFL lamp, step by step:
1) buy a CCFL lamp from eBay, reference:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+Inspiron+B130+CCFL+lamp&_sacat=See-All-Categories
2) take out LCD panel
3) open the back light cover and change the CCFL lamp, reference:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/comment-page-3/
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | Dell Inspiron B130 Notebook
The mute wont turn on,on the dell inspiron
Have you tried going into the speaker settings? We'll assume with a new PC you have Vista installed, click the speaker icon on the right side of the tray, and selecting "Mixer" will enable access to volume control for the output devices and for applications.
If no speaker icon is visible To check the volume controls in Windows Vista, click Start and then click Control Panel. Choose Hardware And Sound and then click Adjust System Volume under the Sound section. The Volume Mixer window will open, and you should see volume sliders for Device and Applications. Click and drag the sliders to view the volume level percentages. If the speaker icons show a circle with a red slash, click the icon so the speakers are no longer muted.
Furthermore, you’ll want to double-check all of your master volume and mute settings.
Dec 29, 2008 | Dell Inspiron 4000 Notebook
Dell Latitude C800
Does this happen with both the power plugged and running on battery?
Check the power modes, because the screen intensity is one of the power saving settings.
Jules
Aug 12, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Black screen
you restore the pc back when it was working fine,you can do in safe mode
May 30, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 4000 Notebook Logo
123 people viewed this question
Ekse
Clive
Clive
