Question about MSI (US54G) 802.11g/b Wireless Adapter
Wireless msi installation
Hey all, i have been trying to install my MSI USB stick(US54G)and having a great deal of difficulty to say the least. This is what i have done: i followed the instructions in the book. First i plugged in the stick and turned on my computer. Then i put in the the installation CD in (InstallShield Wizard) and followed the steps. However after i finished installing it the MSI wireless LAN icon did not appear on my status area and i still have no internet. I tried installing it a second time but the wizard said the software was already installed...so i removed it and tried again but still no icon in my status bar. Any help would be greatly appreciated, Lee
  • Lee88 Oct 10, 2007
    I have been thinking about my problem over the weekend. Do you think that it is a problem with the USB stick i bought or with the installation software, or with the computer itself?  I've been having trouble with the computer store I'm dealing with and would like a second opinion.
    Thank you for your time,
    Lee
  • RaduTanasa Nov 12, 2007
    Hello. I also have an MSI wireless adapter, but I;m trying to make it work on linux. How can I do that?
    Sergeant:
  • 173 Answers
You didn't say what type of computer you have...but some computers have a switch on one of the functions keys with an icon that looks like a transmission tower with waves coming out of it. (Mine is on my print screen button). When used with the Fn key, this turns wireless on and off. Could that possibly be the problem?
Posted on Apr 03, 2017
SOURCE:
ceo007m
  • 49 Answers
SOURCE: I couldn't find a Windows
Simply go to the manufacturers website of your laptop or system.
There you can find all kinds of drivers for different operating systems and for all kinds of model of their systems.
Depending on the site, these questions are needed to help you
the model of your system
the operating system you're using and
the list of drivers for that system appears
Posted on Dec 22, 2010
  • 624 Answers
SOURCE: msi k7 kt2 conbo-l motherboard
If you're getting this message during the POST and there are IDE drives then chances are you haven't configured the drives correctly.To correctly configure two drives on an IDE channel you need to either: - have one drive set as Master (using jumpers on the back of the drive) and the other as Slave OR - have both set as Cable Select (CS) with the appropriate cable. If you are unsure how to proceed look at your original drive and let us know how the jumpers are currently set.
Posted on Jan 30, 2007
map9966
  • 2351 Answers
SOURCE: problems with MSI K8N Neo3 motherboard ethernet adapter
Hi mush187, the SMbus controller is basically your chipset drivers. If for some unseen odd reason it did not install correctly you will not be able to install other drivers. (which seem to be the case). Here is the link to you're board & it's drivers. (click on it).
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=170
This is nVIDIA's web site. This is where you need to go in order to download & install the latest chipset drivers.
http://www.nvidia.com/Download/index.aspx?lang=en-us
I understand if you can't get you're network driver installed you can't get to the nVIDIA site. So can you install a PCI network card, (temporarily)? The cool thing about nVIDIA's web site is it will scan your system & suggest the proper updated software.
It's only a suggestion.... In either case the MSI link above will allow you to download the drivers you need.
Good Luck!
If I can be of more service, just ask.
Mike
Posted on Apr 07, 2008
  • 6 Answers
SOURCE: SolutionCenter.msi
Not much info given here, but try unloading the process at startup by Clicking the "Start" button, select "Run", type "msconfig" without the quotes, and hit Enter. On the "Startup" tab select and remove the check mark next to the startup item that is associated with the solution center. This item may be obvious or you may need to plug a few of executable names into a Google search to find the culprit. OK the removal and restart the computer. Depending on the operating system you will be prompted not to show a notice about changes made. Not to worry, in almost all cases the procedure can be reversed if by chance the wrong item is removed. PC-Professor, good luck!
Posted on Jan 16, 2009
leecom72
  • 4806 Answers
SOURCE: MSI 875p neo-lsr - startup problem - BIOS froze
Hi there.
Try to clear the CMOS by removing the power cord, taking the side panel off the tower and looking at the motherboard near the battery for a coloured plastic jumper like this >>>>>>
If there is a plastic jumper there move it to the other position and hit the on/off button to clear the CMOS, then put it back in its original position, replace the side panel and power the machine up.
If there is no jumper there you will need to remove the power cord and take out the motherboard battery for an hour to reset the bios.
You can get the LAN driver here >>>>>>
http://drivers.softpedia.com/progDownload/MSI-875P-Neo-LSR-FIS2R-Intel-10-100-Ethernet-Driver-80270-Download-44480.html
If you need anymore help or advice please do not hesitate to post back.
Good luck and thanks for using FixYa!!
Posted on May 24, 2009
Msi cr700 media fail check cable
Hello, ihave same model MSI CR700 and have same problem, on booting up it says media failure check cable. Im try reinstal windows but freazed on instaling, Im try instal Ubuntu on USB stick and is working, I can see my disc but is like empty but yesterday there was all my files and no problem to opened files and pictures. what you thing problem in harddrive, cable, conector or motherboard. thanks
May 01, 2012 | MSI CR700-012US (816909061604) PC Notebook
Draiver for msi(ms-6970) compatible for windows7
Hey there, get the latest drivers for the Bluetooth adapter for the ms-6970 MOBO here:
http://www.laptop-software.com/compaq-drivers/msi-btoes-ms-6970-bluetooth-usb-dongle-windows-driver/
Have fun :)
Aug 15, 2011 | MSI ms-6970 Bluetooth Wireless Adapter
I need MS-6758 sound drivers, BIOS version 1
There are two versions of your motherboard listed under the MS-6758 model. I've posted links for the sound driver for both models. Try and download and install the driver from the first before trying the second link.
32 bit/64 bit Sound Driver for the MSI MS-6758: http://download2.msi.com/files/downloads/dvr_exe/Realtek_AC97_MB.zip
If the installation fails after you download and install the driver from the first link, then try this link next: http://download2.msi.com/files/downloads/dvr_exe/ADI_ICH5.exe
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Apr 18, 2011 | MSI MS-6758-040 Motherboard
I need drivers for msi us300ex
hey, I found a driver for this USB wifi stick here>
And it works on my win xp sp3 :) Driver should be also for win7, vista in 32/64 bit versions.
http://de.msi.com/product/net/WLAN-11n-USB-Micro-Stick-US300EX-Lite-.html#/?div=Driver&os=Win7%2032
Good Luck!
Jan 08, 2011 | MSI US300EX Lite II Wireless N USB20...
I couldn't find a Windows 7 driver for my MSI Wireless Stick US54G. Where can I find one? Greetz
One might be able to use the emulation mode for the older dirver. I don't think that if it doesn't install automatically that there is a standard windows 7 driver for this device because b and g are older technologies as compared to the standard 'n' adapters now available.
Dec 22, 2010 | MSI (US54G) 802.11g/b Wireless Adapter
Need a driver for MSI MS 6861 Wireless adaptor
Hello.
Go to this website:
http://www.wireless-driver.com/wifi/2006-4-12/msi.htm
Scroll down to:
MSI Wireless 11G USB 2.0 Stick Model# US54G (MS-6861)
Select your operating system and download.
Hope this helps.
Dec 13, 2009 | Computers & Internet
I need a driver for US54G/MS-6861 MSI wireless
go to this web site you got it your driver folder
Jun 11, 2009 | Computers & Internet
Need instal software for msi rg54gs wireless router?
is the router brand-new? If not, trying re-setting it using the recessed reset button at the back....it is possible that a previous configuration of the router might have changed it's local IP address.
Apr 21, 2009 | MSI RG54GS Wireless Router
MSI PC60G Wireless Adapter Driver for vista
Hi Salmar,
The driver can be found on the MSI site here:
http://www.msi.com/index.php?func=driverfile&dno=2284&i=1
Pick your region and download.
This covers both Vista 32bit and the 64bit operating system.
Run the install utility and let windows recognise, configure adn install it fo ryou.
Reboot and check the wireless operation.
Nick
Jan 06, 2009 | MSI PC60G (MS-PC60G) Wireless Adapter
MSI (US54G) 802.11g/b Wireless Adapter Logo
112 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
