HP iPAQ hw6515 Pocket PC Logo
m
michael percival Posted on Nov 11, 2013
Forgot my apple id, and my password for my apple ipad
Forgot my apple id and my password, the email address I had [[email protected]] is no longer my email, my new email is [email protected]
jeremy carl mays
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 01, 2014
jeremy carl mays
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
664
Points
Forgot my apple id and my password, the email address is no longer my email, my new email is [email protected] but I had find my ipad turned on how can I make a new apple id without knowing the apple id I had on it or the passwork
I forget my icloud iphone password
To recover your iCloud password, you can do the following steps on iPhone and iPad, which is the simplest way.
Step 1. Tap on your iPhone/iPad screen to open the Settings app. Then scroll down to tap on "iCloud".
Step 2. After entering the "iCloud" interface, you can see the option Forgot Apple ID or Password?. Tap on the option and you'll have two choices:
A. If you know your Apple ID (An Apple ID is the personal account you use to access Apple services like the App Store, iTunes Store, iCloud, iMessage, the Apple Online Store, FaceTime, and more. It includes the email address and password you use to sign in.)and cannot remember the password, then you can type in your email address and click "Next" to start the process to recover iCloud password.
B. If you forgot your Apple ID, tap on the Forgot Apple ID option and fill out the following information: Last Name, First Name and Email to recover the Apple ID, then click Next.
Note: You are supposed to answer all the security questions which is relevant to your Apple ID, and then follow the directions shown on the screen to complete the process.
After answering all the question, you can finally reset the iCloud password and then log in as usual.
For more details, check: How to Recover iCloud Password
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Forgot iPad apple I'd and password
Go to https://appleid.apple.com/ and reset your id. You should have create security questions to answer. You had to use an email to create your id.
I cant get into my iphone i dont know my icloud account, what should i do?
Hello Diana,
First, don't freak out, we're human and this stuff happens. Apple provides multiple ways to recover a forgotten ID login or password, and you can start the recovery process either directly on an iPhone, iPad, or iPod touch, Mac, Windows PC, or just about anything with a web browser.
The different processes described below will work to recover a forgotten Apple ID (meaning the email address used to login), and/or reset a forgotten Apple ID password. This can be particularly helpful if you're setting up a new device for yourself or someone else, switching a device to a credit card-free ID, or changing the Apple ID associated with a device, and you can't remember the pertinent login information, or if your email changed at some point and you didn't update your Apple details to go along with it.
Before anything else, know that you can always Contact Apple for help with Apple ID account security if you want assistance through official channels to regain account access, which may be the best option for users who are overwhelmed or confused.
What if this doesn't work, or what if it doesn't find your Apple ID? You can try one of the next two options:
Find a Forgotten Apple ID by Email or Old Email Address
This is a more advanced trick to search multiple email addresses, which is incredibly helpful if you switched email accounts at some point in time and that's what has caused the login problem. This can be done with any web browser in iOS, OS X, or Windows:
1. Open the web browser of choice and go to this Apple iForgot website: https://iforgot.apple.com/appleid (creative name, eh?)
2. Enter the first and last name associated with the Apple ID, your current email address, and any and all prior email addresses to start the reset process
3. Answer the security questions associated with the user to complete the reset process
This will help to find the Apple ID, but if you can't recall the password to that ID then you'd need to go to the next step as well.
Reset an Apple ID Password from the Web
You can also start the password reset process from the official Apple ID website, this also can be done any device as long as you have a web browser:
1. Go to this My Apple ID site and under "Manage your Apple ID" choose the "Reset your password" option
2. Enter the email address associated with the account and answer the security questions as usual to complete the password reset process
Finally, if you're completely stuck, you're annoyed, confused, or none of the above has worked, you can contact Apple directly about your account here (Contact Apple for help with Apple ID account security ) or at you local Apple Store and in many situations they can help you to regain access again.
Create apple ID
How to create new Apple ID on your iPhone or iPad
-Launch the settings app
    -Tap sign in to your iPhone at the top of the screen
    -Tap don't have an apple ID or forgot it?
    -Tap create apple ID when the windows pops up
    -Enter a birth date
    -Tap next
    -Enter your first and last name
    -Tap next
    -Select your current email address or get a new iCloud email address
    -Enter your email address
    -Create a password
    -Verify the password
    -Select a security question
    -Type in answer
    -Repeat two more times
    -Agree to the terms and conditions
    -Tap merge or don't merge to sync iCloud data from safari, reminders, contacts and calendars
    -Tap OK to confirm that find my iPhone is turned on
Sep 06, 2014 • iPhone Apps
2answers
Forgot apple id and password
Your Apple ID and password is the key to gaining access to the App Store, and Apple has a username and password locator tool to recover forgotten information.
Your Apple ID is usually the same as the primary email address attached to the account, and cannot be deleted once created.
As a security precaution, Apple resets your account password and allows you to create a new one rather than display the previous password.
Visit the Apple Forgot ID page, and click "Forgot Your Apple ID?" underneath the text field.
Enter your first and last name, current email address and up to three previous email addresses. Click "Next" to use the Apple ID locator to pull up all Apple accounts linked to the entered email addressees.
Click "Email authentication" and click "Next" to have the Apple ID sent to your email address. Open your email account, and open the message from Apple.
The message contains a link that redirects you to the password reset screen.
Enter the new password, and reenter it in the confirmation box.
Click "Reset Password" to submit the changes.
A confirmation email is sent to your email account with the name of your Apple ID and a confirmation of the new password.
Click "App Store" on your Macintosh's desktop dock and click "Store" on the application's menu. Click "Sign In" and enter your Apple ID and password.
Click "Sign In" to log into your account.
http://support.apple.com/kb/HE37
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
