I HAVE PURCHASED OLD IBM THINKPAD R30 JUST 2DAYS BEFORE ITS DISPLAY WAS BLURT IT CAUSES VERTICAL AND HORIZONTAL LINES SELLER TOLD ME REPLACE LCD & INVERTOR KIT CONNECTING STRIP I DID REPLACED IT BUT THE SAME PROBLEM WHEN I PRESS BACK SIDE OF LCD DISPLAY COMES FOR AWHILE GOES OFF BY FADEING ITS COLOURS IS THE LCD IS DAMAGE PLZ HELP ME NOW I M USING MY LAPTOP CONNECTING XTERNAL CRT MONITER .
Hi. I've worked on several of these thinkpads which had this problem. There are a couple of things it could be depending on what the display actually looks like. If it "whites out" , or has lines. First, make sure the ribbon cable is connected properly. If the lcd lights up at all, the inverter is fine. Next, while booting the machine, press in on the memory; this might work better if you only have one memory stick in the machine. Just putr pressure on the memory towards the motherboard. I know it sounds weird, but it's a possible problem. If that doesn't do it, the lcd may be shot. Good luck
Similar problem here...AC & battery lights on the T61p show. Hit power on button, caps lock...
(More)
Similar problem here...AC & battery lights on the T61p show. Hit power on button, caps lock lights up briefly, + fan starts, then nothing (and nothing shows on the screen). Tried removing battery and booting from dock and power cord. Strange.
