Question about Kaser Corporation Mambo Mano Digital Media Player
Converting video files
Hello all, I tried to convert some video files and I was able to convert in .amv format, but my player doesn't recognize these files. My player is able to see only .mtv files - like the sample file provided with the player. Can you recommend me some converters that can convert to .mtv format files? I found some alternative convertors that may work but I am not sure what are the parameters of supported .mtv video format. Any idea please?
  • dimitar Oct 06, 2007
    I found a solution myself.
    I found a good MTV converting tool at: http://www.uxcell.com/public/mp4/mp4note...
    Use 1 or 5 frames /sec.
    My MP4 player supports all possible resolutions.
    Good luck to all.
  • Anonymous Dec 28, 2007
    I have tried converting video files to .amv, .asf, .mp4, .wmv and .mtv but they don't show up in the browse list after I sync then.
    Help Please. Thanks
  • 26 Answers
This mtv coverter may help, sir. Try to find it at http://www.mtvconverter.com
Posted on Dec 10, 2008
    Problem Solver:
  • 4 Answers
Go to www.kasercorp.com and down load the manual. it will tell you were to get the mtv converter
Posted on Feb 29, 2008
SOURCE:
How do you convert video to amv
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Sep 18, 2012 | Jensen 2GB Flash MP3 Player SMPV-2GBUB -...
I have the AMV Converter software for the Electro Brand MP2614 Mp3 Player, but every file I attempt to convert just says error. What do I do? Or rather what am I doing wrong?? I have tried converting .flv,...
1.Is the Compatible with the Operating system installed
2. Software may be corrupt
3. check the web for free converters that will do the same. Suggestion: format factory.
Jul 06, 2011 | Computers & Internet
Converting itunes videos to amv files for my kids mp3 My kids want music videos for the mp3 players....mp3 only support amv files....itunes downloads won't work with...help
I have been using this program with real good results. It will convert any video into a mp4 which is what you need. http://www.any-video-converter.com/products/for_video_free/ Copy this address into a new window.
Jan 13, 2010 | Coby MPC895 MP3 Player
Do you have software converter from a VOB
Check out the link below for your requested software:
AMV Video Converter (Scroll down on page and click on freeware free download)
Nov 30, 2009 | GPX Televison & Video
I can't put videos on my mp3/mp4 player
Sir please connect your device to your computer and see if any indication is shown on the display of your mp3 player
if yes then open my computer and a new device will appear under the removable devices...please open it and if there is a folder named mp3 to music then also open it and copy paste all music you want
If not then please make sure in the settings of the device that USB is set to MASS STORAGE MODE
Thanx and i hope this helps
PLease rate this solution
Jul 17, 2009 | Audio Players & Recorders
AMV movie dowloads - JNC Movie Mojo ( SSFM-220 )
How to convert wmv, asf, avi, mpg to amv files? iOrgsoft AMV Converter is an easy to use video-to-AMV and AMV-to-video converter application that enables you to extend MP4/MP3/MTV capacity by converting various video files into AMV workable format. AMV Converter has powerful editing capacity that you can customize source video files into different resolution, bitrate, frame rate, etc.
If you have lots of video sources but unable to get them onto your player, AMV converter should be your ideal choice. Please follow the guide below on how to convert AMV video file to or from using the iOrgsoft AMV Converter.
spacer.gif icobuy.gif Buy Now spacer.gif icon-downarrow.gif Download RMVB Video Converter free trial spacer.gif How to use video to amv Converter
How do you convert video files into AMV video files that are compatible with your mp3 mp4 player?
Step 1. Download and install iOrgsoft AMV Converter
iOrgsoft AMV converter is a simple-to-use program with intuitive way of operation. You are supposed to download a trial version to evaluate the program by converting video into AMV, we welcome you contact our customer service with your problem.
Step 2. Load video info
Click ADD Files to load video info. You can load as many video files in different formats as you like, the batch mode and powerful code pack within the program can easily take care of every thing.
Step 3 Change defaults setting
After load video files, you can now tweak various values that directly impact on the output result. Hit Option will open a window where you can trim, crop and add effect to the source video. Finally, check the box before Merge Files into One on the bottom of the panel, all the files can be merged into one then.
Step 4 Convert video
Hit Start, the entire list of source video will turn to your delivery format as you preset The time takes vary file and setting you have made..
Mar 19, 2009 | JNC Computers SSF-M636 Digital Media...
"Format Error"?
try converting the videos to windows media video (WMV) file formats
Jan 22, 2009 | iLO (2 GB) MP3 Player
I need help with Craig CMP622E MP4/video player
for the video issue, I've found that when I'm downloading something from youtube or something like that, if I save it as a .wmv file it will convert it, and for limewire the videos I download are all .avi and those can be converted as well. Hope this helps a bit :D
Dec 25, 2008 | Craig (731398443796) Shelf System
What kind of video file does the coby mp-c7082 play? Also, how do i download these files to it?
The software, esp the AMV converter necessary for converting movies, can be found by entering your model # at:
http://www.cobyusa.com/?p=doc
I had to click on support -> mp3 & Mp4 and then the exact model # - I couldn't get to it through the regular mp3/mp4 page - trust me, it's there
It supports AMV format only, so it must go through the AMV converter on the Coby website
Jun 22, 2008 | Coby MP-C7082 Digital Media Player
Video files
Try put in it in manually Go to the following folders Record > AMV > and put the video in there....remember the video must be converted into a AMV file
Nov 08, 2007 | Delstar DS-2821 Digital Media Player
Kaser Corporation Mambo Mano Digital Media Player Logo
181 people viewed this question
Top Kaser Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Kaser Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
