Question about Canon PowerShot A80 Digital Camera
Help with code
My canon powershot a80 has a code when i turn it on E18
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Posted on Nov 16, 2007
SOURCE:
When i turn my cameraon the lens opens ans then shuts automatically with an e18 message on the screen and then makes a strange whirring noise
Go to this website for help. This is a common problem and there is an actual website devoted to this very problem. www.e18error.com
May 06, 2011 | Canon PowerShot A80 Digital Camera
Solve e18 problem
E18 refers to a lens issue, the camera needs a new lens unit, or the lens repaired. Marginal repair now.
Jun 08, 2010 | Canon PowerShot A80 Digital Camera
Have Canon PowerShot A80. New batteries, turn on and it automatically turns off with a buzzing/clicking noise... Window shows error E18
Here's some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try:
Nov 14, 2009 | Canon PowerShot A80 Digital Camera
My Canon PowerShot A80 Digital Camera on and then off
If the E18 error code comes along with unusual noises while moving the lens, there may be a problem with the mechanics. Just tap the camera on a solid surface a few times. I had the same problem and tapping helped just fine.
Mar 01, 2009 | Canon PowerShot A80 Digital Camera
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
I have a powershot a80. When I turn it on I get an E18 error code in the window. The lens makes a clicking noise like it's trying to open and it doesn't open.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
E18 displayed on Powershot Canon A80
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Nov 02, 2008 | Canon PowerShot A80 Digital Camera
Canon powershot sd400 error code E18
Yes !! I wacked it a couple of times on a hard surface and it started working again after I dropped it and got the dreaded E18 error mesage in the middle of a Jewelry shoot. wm
Oct 14, 2008 | Canon PowerShot A80 Digital Camera
Canon PowerShot a620
Hey nanasandy,
This is a common error message for many Canon camera models. It is most often caused by the lens getting stuck by either damage to the lens mechanism, or something got stuck in the lens (i.e. sand). One thing you could try is blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens mechanism. If this doesn't work I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 25, 2008 | Canon PowerShot A80 Digital Camera
E18 Error
Sorry to hear that. I have an A80 also, and I really like that camera (swear it takes better pictures than even my A620).
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
May 11, 2008 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
