The roll pin in my snapper re riding mower broke off on both sides of the steering shaft, the pin is stuck inside the shaft, I used a punch to knock it out, but the punch broke off inside the shaft also, I am too weak to swing a hammer hard enough, any suggestions
SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
SOURCE: Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
SOURCE: belt diagram for snapper lt 200 riding mower
PLEASE SHOW ME A DIAGRAM OF ACTUAL BELT AND PULLEY'S FOR SNAPPER LT 200, MODEL #2690441?
