Question about Alps MD 1300 Thermal Printer
Alps md 1300 only prints in black
I purchased an alps md 1300 off of ebay to produce some decals. I got the printer working but it only prints the selected photo or test page in black. All the color cartriges are in the printer. It just does not recognize that it should print in color. I've check the settings on my computer and it should be printing in color. Is it the printer, driver, or settings?
    Sniper:
  • 58 Answers
First of all, Alps MD inks do not "Dry up". They are dry to start with!
It sounds like you may be running XP, with the Microsoft driver for this printer installed. You need to load the Alps driver, which you can get by joining the alps or alpsdecal group at http://groups.yahoo.com. You can find the driver in the files section of one of the groups.
Posted on Mar 20, 2008
    New Friend:
  • 31 Answers
Do you have the Windows driver installed, or the Alps driver? If it says MD-LPT1 vs LPT1 than you've got the right printer driver installed. If it's just LPT1, it won't work correctly, that's the printer driver that Windows THINKS will works with the printer, and I promise you, it won't. You need to get the correct driver before anything will work properly, including the test page. If you do have the correct printer driver, make sure you have enough ribbon in the color cartridges. They're hard to come by, but there are sites online, or they can be found (for a price) on eBay. Best of luck! (btw, if you don't have the correct drivers, there is someone selling drivers that work up to XP on eBay--there are no drivers that work beyond XP).
Posted on Nov 26, 2010
  • Dormouse Nov 26, 2010
    I didn't read the previous comments, so I see what I've said is a repeat of what others have said, but as for the colors of the cartridges, the blue ones are for photographic printing only, and you require photographic paper made my Alps. The greyish cartridges are for any other paper, including the photo-realistic paper, also made by Alps. If you do get up and running, and have the blue cartridges, make sure you change the orange strip that comes in all packages of photographic paper. That is the only time you need to change it. When the package is used up and you start a new package of paper, change the orange strip. Hope you get it going! (and remember, when looking under printing settings, look for the MD LPT1 and delete the LPT1 if you see it, unless you have another printer running that is using it)
The correct color cartridges for a 1300 are gray in color. When I purchased my 1300 it came with a set of cartridges only they were blue. I could only print black. If this is not the problem then see what driver you are using. I have the factory supplied driver for the 1300 for use in windows xp. I works great. However when insstallaing the driver in windows xp the MS version will sometimes also load and the computer wants to make that the primary driver. This will also cause printing problems you must use the straight MD1300 printer selection not the MS MD1300. Hope this helps. I spent many frustrating days trying to make mine work and when you finally get the bugs out they are great.
Jim
Posted on Oct 22, 2008
  • 106 Answers
At first try reinstalling the software, if it does not help check for the colour catridges. Those might have dried up.
Posted on Oct 07, 2007
SOURCE:
My problem is in my Alps MD 1300. Two layers of white print without problems, but when I print CMYK over white horizontal lines appear about ruining my work. I use "white Based (MDC-OPWH)"...
The MDC-OPWH is Opaque White. It's meant to be used as an overcoat when making things like Iron-On transfers when they are applied on dark backgrounds. Regular white is used for undercoating for things like waterslide decals.
May 04, 2012 | Alps MD 1300 Thermal Printer
Can our ALPS MD 1000 printer work with Windows 7? We used it when old computer had Windows XP on it, but that crashed and bought HP with Windows 7 now... we need Alps to make waterslides for custom rod...
There are NO Windows 7 drivers for the ALPS MD printer. I've read that you can run an XP virtual mode on Win7 that allows you to use the printer. If you are comfortable tweaking the OS, it's a workable option. I picked-up an old (and cheap) laptop on Craigslist and printed my decals from there.
Sep 15, 2011 | Alps MD 1000 Thermal Printer
I'm looking for the manual for the Alps MD-1300 printer, I need to know how to print spot colors
The 1300 prints spot colors the same way as the other ALPS printers. To print spot colors, create a mask or layer using only black with your artwork. Select the spot color you want and the black areas on the mask will be printed in the spot color. Make sure that you check the overlay box so the printer retains the printer. You also need to make sure you are using the ALPS printer driver supplied with the printer and NOT the default Windows plug and play driver.
Nov 26, 2010 | Alps MD 1300 Thermal Printer
I'am trying to print a decal on am alps 5500
You could try using spot colors for each layer of the decal. This gives you the highest resolution.
Mar 31, 2010 | Alps MD 5000 Thermal Printer
I need printer drivers for alps md 2300
www.opendrivers.com/driver/.../alps-printer-md-2300-driver-6.40-win98-95-me-free-download.html
www.updrivers.com/drivers/.../Alps/MD_2300.../16562.html
www.howtodrivers.com/model34028.html
Nov 08, 2009 | Alps MD 1300 Thermal Printer
My alps md 5000 doesnt seem to be printing decals as clear as it
these printers are flaky. There is a reason why the mainstream never picked ALPS up. The image quality stinks and the printer break down constantly. Koolaid drinkers in search of the grail love them.
Oct 28, 2009 | Alps MD 5000 Thermal Printer
Lines through my md 1300 alps printer
It sounds like the head has been damaged. Unfortunately, there is no fix for this, as Alps stopped production of these printers years ago, and now do not offer repairs for these printers.
If you still want a dye-sub capable Alps printer, the only model available is the MD-5500, which you can find here: http://www.alps-supplies.com
Feb 15, 2008 | Alps MD 1300 Thermal Printer
Alps md1300 lines through ink
Nov 04, 2007 | Alps MD 1300 Thermal Printer
Alps MD 1300
The printers are out of production, and out of support.
Oct 11, 2007 | Alps MD 1300 Thermal Printer
Alps MD 1300 Thermal Printer Logo
357 people viewed this question
Top Alps Office Equipment & Supplies Experts
Clive
Clive
defcon000001
Level 1 Expert
Jesse Walters
Jesse Walters
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
