Question about IOGear GKM541R Keyboard/Mouse
Mouse for Iogear GKM 541 RA is sporadic
I have the receiver in my compute in the basement BUT literally right below me. It's hooked to my 60" TV. The keyboard works fine but the mouse cuts in and out....as if it has a weak signal. Any ideas?
  • 341 Answers
Try putting the mouse and receiver on the same plane.
Posted on Nov 26, 2008
Toggle keys don't work as advertised
Hi David,
I located and downloaded a copy of the manual and found the details for [Scroll Lock] [Scroll Lock] [Enter] on page 8 that simply says:
"This will switch everything (KVM and sound) to the next port."
There is no mention of this keystroke switching to the next port "only if there is a computer connected" as you indicated in your question. It would seem to me that if the KVM switches to the next port when it receives the [Scroll Lock] [Scroll Lock] [Enter] keystroke - it is working as described in the manual that I downloaded from the IOGear site.
The only remaining commands accepted by the KVM are :
[Scroll Lock] [Scroll Lock] [a] [Enter] which is a 5 second Auto Scan mode
and:
[Scroll Lock] [Scroll Lock] [a] [n] [Enter] which is nearly identical as the a5 second Auto Scan mode - except the the numerical value you type in place of [n] is the number of seconds spent on the next port.
Double check your manual and if you're still having trouble - contact IOGear directly below:
Toll Free 866-9-IOGEAR (USA)
Phone: 949-453-8782
19641 Da Vinci, Foothill Ranch, CA92610
www.iogear.com
support@iogear.com
Dec 16, 2013 | IOGear GCS634U KVM Switch
Just hooked up the KVM cable and when I switch to the second computer, the mouse and keyboard do not work. Can someone help me with this?
Sounds like there's a bad connection on the second computer, may just have to plug another mouse/keyboard in.
(I sometimes use a wireless usb keyboard/mouse combo)
Jul 03, 2010 | IOGear GCS632U 2-port KVM Switch
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
LIGHTS ARE ON CURSOR DOES NOT WORK HAS BEEN WORKING FOR 2YEARS WITH NO PROBLEM .HAVE ALRADY UNPLUGED AND RESTARTED ALL SYSTEMS. IT IS AN IOGEAR GKM531RA WIRELESS. KEY BOARD IS WORKING FINE -BATTERIES IN...
The GKM531RA comes with a USB dongle which is connected to the computer.
Since you mentioned that the batteries are okay. Locate the small button on the dongle (connect button) and look for the connect button underneath the mouse.
Hold the connect button at the same time for 5 seconds ONLY, and release them both. The mouse should work.
If that did not help, try to use the keyboard and mouse in a different computer.
Last, contact IOGEAR and have them RMA the device. Meaning that the mouse has a hardware defect.
Thank you and good luck!
Dec 25, 2009 | IOGear (GKM531RA) Keyboard and Mouse
My wireless works sporadically. I have changed
Okay. Haha i just had same problem at work. Try moving the receiver right in front of keyboard and mouse. I found that the range for the mouse is a little greater than the keyboard. Remember the range on this thing REaLLY sucks, mine wont even go 2 ft. Give it a try and let me know.
Aug 03, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Iogear problem
Hi. What device are you using? I suggest that you check if the keyboard is hooked up to the correct port. You will see underneath the KVM an icon that looks like a mouse and a keyboard. Make sure that everything is hooked up correctly. It should be okay once you connect them properly. Press "scroll lock" twice.
Jun 06, 2008 | IOGear COMBO ION GHD135C160 160 GB Hard...
A mouse that wont work at all
Below is a link to the pdf document for your mouse. Please scroll down to the section titled 'Windows'. This section refers to the blinking light on the mouse, and what steps you need to perform next. I hope this helps.
http://www.iogear.com/support/manual/GME223R%20manual%202.pdf
May 24, 2008 | IOGear GME223R (881317000262) Mouse
My Iogear mouse wont work
In order for you to make the mouse work with your computer, please try the steps below:
1. Make sure that you're using fresh batteries.
2. Make sure that the mouse is turned on.
3. Hold down the connect button on the receiver (the mouse cradle) and hold down the connect button under neath the mouse at the same time for five seconds and then release the buttons.
4. Try moving the mouse around and that should work.
Apr 15, 2008 | IOGear (GKM521R) Keyboard
IOGear GKM541R Keyboard/Mouse Logo
148 people viewed this question
Top IOGear Computers & Internet Experts
Damen Wong
Damen Wong
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
