Question about Kenmore 22422 Top Load Washer
Kenmore washer switch
My top loading washer wont stop cycleing on its own once the timer hits the off it continues on to the next cycle on the timer
  • Anonymous Sep 12, 2008
    Kenmore top-loading washing machine: at end of cycle it advances to the next cycle. ALSO, the agitator functions WHILE the machine is filling. (Otherwise, there is no problem with water levels.)
    Is this just a timer problem?
Sounds like a timmer problem and needs replacing
Posted on Oct 05, 2007
Machine fills up with water, goes through the agitate cycle then stops and wont go into next cycle
Your Lid latch switch is most likely broken, you will need to replace it, you can not bi pass this switch. you can order it from your closest appliance distributor.
Unplug or turn off breaker to washer.
Replace by removing front panel, should be 2 screws at the bottom of washer.
Slide and depress lid latch down to release.
unhook wires and reinstall the same.
May 07, 2011 | Kenmore 22422 Top Load Washer
My kenmore 700 washer wont stop it just goes to the next cycle. If I dont catch it right when it stops it clicks a few times and starts the next cycle one after another.
If your machine has a mecanical timer then then the timer is bad, if your machine has digital functions then you have a bad control board.
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
Washer stays in cycle and doesnt advance to additional cycle
Hi, It sounds like you timer has gone bad. Would need more of the model # ro be sure on what type timer you have.
Please let me know if I can assist you further.
Jun 05, 2009 | Kenmore 22622 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Whirlpool washer sometimes stops after the wash cycle
Sounds like the timer has given up. I bet if you just barely turn it, it will continue.
It's a common problem with timers like this.
Replace it.
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
Oct 31, 2008 | Kenmore 23822 Top Load Washer
sounds like the water isnt shutting off once it starts washing,check the valve assy or may have a timer fault,try turning off the taps once it starts washing and see what happens if it starts pumping then timer?
Mar 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
42 people viewed this question
Sal De
 Brian Main
Brian Main
