Question about Sanyo Katana SCP-6600 Cellular Phone
Sanyo MI I press the camera/video buttons and it won't go to the camera/camcorder, it goes right back to the screen saver (main) page...what gives? it's a new phone.
I had the same problem with mine when it was brand new...i brought it back and they said that they had a bad batch of them and the only thing they cud do was replace it...good luck
Posted on Mar 02, 2008
Sanyo Xacti 14 mega Full HD camrecorder doesn't turn on
check battery or connect to the mains and remember power buttons are fragile and unfortunately this is the button we use quiet often or failure take it in for check up
Dec 22, 2013 | Sanyo Xacti C6 Camcorder
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
When I turn the unit on, there isn't an image on the monitor. You can press the camera button and the flash goes off. There just isn't an image in the monitor. Please help!
If it takes a picture successfully, then your display is bad - more likely the back light inverter. Check your memory card and use a computer that can read it.
Dec 14, 2010 | Sanyo Xacti VPC-E1 Camcorder
Hi I have a new sanyo xacti vpc-ca9. It will not boot up - just a blinking red light on the top. The battery is charged and there is a 16GB SD card installed. Any ideas? Garth gartht@mac.com
I have the sam camcorder. It has the same problem. When you press the on/off button, it does not do any thing just red light blinking on the top. After wandering with buttons without really knowing what I am doing, I took it to Sanyo service center. They found the ribon connecting the LCD to main body being damaged. They replaced it and charged me $75 for that. After that the camcorder works good. I saw the ribon is very vulnerable. If you twist the camcorder just a little hard, that ribon may get shocked.
Aug 04, 2010 | Sanyo Xacti VPC-CA 9 Flash Media Camcorder
Sanyo xacti digital camcorder screen not working when opened out
Hi!
It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
Sorry for the bad news, but hope this helps.
Tom
Sep 27, 2009 | Sanyo Xacti E1 Waterproof Camcorder
I need to set time n date. I have no manual. How do I set time & date?
power button on to left(camera). press the display button until the mode screen appears. press the up or down arrows to select menu then press the center of the operation button Press the operation button again and execute highlites press oper button again it goes to setting 1.Press arrow up to others 2 press oper button again. arrow down to settingand press oper button again THis gives you the month,press again for day and so on . arrow up or down to change year and time.
Jun 26, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Panasonic PV-DV103 Playback Problem
check ur recording mode it may be on snapshotmode change it. or clean ur cam head
Jun 04, 2009 | Panasonic PV-DV103 Mini DV Digital...
SPLIT SCREEN PROBLEM
You can buy a new LCD and flex cable for $78 at the place Sanyo recomended to me. It takes a week for them to order it and a week to ship out. Call 1-800-421-5080 and give them part # 6450930331.
Mine has the same problem. I took it apart and by pressing on the flex cable my picture was restored. As soon as I let go the screen would go. Trying to decide between replacing the part or the camera.
Jun 02, 2009 | Sanyo Xacti VPC-E1 Camcorder
Dell E178FPf LCD monitor goes to standby and won`t come on again
Check your Power options in Windows.
right click on the desktop. select properties, Gop to the screen saver tab, click on the power button at the bottom right and check to see if its set to turn off or standby the monitor, turn this off.
Keep the screen saver on and set it for like ten minutes.
Also, on the monitor itself, it may have a sleep or power save option set as the default. check all the monitor settings on the actual moniotr itself.
Mar 31, 2008 | Dell E173FP 17" LCD Monitor
Please help me fix my camcorder
the record button is no good it happens on your model and the zr 500 and 600 as well needs to go to canon.
Nov 15, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Sanyo Katana SCP-6600 Cellular Phone Logo
Top Sanyo Cell Phones Experts
270rexton
270rexton
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Steve Allison
Steve Allison
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
