Question about JVC KW-AVX706 Car DVD Player
JVC KW-AVX706 front face problems
Front face does only closes half way keeps throughing out an error, to press open button there is no physical damage
  • 1 more comment
  • TFirzlaff Dec 26, 2007
    Face plate dose not close when you hit the close button, and gives an error message: Position Error Push Open Key. Dose anyone know what is causing this problem? Unit it practically brand new, with know physical damage.
  • CostlyOsbn May 05, 2009
    I have a brand new JVC AVX720. It says, "Position Error Push Open Key" when it starts up. The Open key just slides the face down and when it comes back up it still does not close all the way . The tilt function does not work either, it just displays the same error, "Position Error Push Open Key". Does any one know how to fix this?
  • dimakatso May 16, 2015
    my face doesn't open it gives me this message "mecha push reset " what must I do?
For ppl still having this problem.. more than likely the dash kit is to small and not allowing the radio to close properly. soulution: get one that fits, or get a dremel and shave down the plastic on the dash kit that prevents the radio from closing... hope this helps some1
Posted on Sep 03, 2010
    New Friend:
Write your answer...my phase doesn't open it give me this message "mecha error push reset " what must I do?
Posted on May 16, 2015
Need color code for 16 pin connector, power plug
Pin Number Wire Color Function 1 White Left Front Positive 2 Green Left Rear Positive 3 Violet Right Rear Positive 4 Grey Right Front Positive 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front Negative 10 Green/Black Left Rear Negative 11 Violet/Black Right Rear Negative 12 Grey/Black Right Front Negative 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
Sep 18, 2015 | JVC KW-AVX706 Car DVD Player
I want to heek up my iphone to my jvc kw-avx706. i dont have a direct jack for it but i have an OE remote wire in the back coming out of my deck on the harness. what is that wire used for and is there a...
If the wire your referring to is blue/white it is to cut on external amplifiers. If you go to Crutchfield.com and type in your model number there is a pdf file for the manual on the right hand side about half way down, it will also show you what accessories for ipod control.
May 16, 2011 | JVC KW-AVX706 Car DVD Player
I have a jvc kw-avx706...is there any way i can hook my iphone up to it so i can listen to my ipod?? if so let me know please thank you
Hello, there are two options. You could use a mini jack and plug it into your headphone jack on your Ipod and plug the other end into the aux jack on the front of your JVC unit. However you would have to have access to the ipod to control tracks and it will not charge the ipod. Or you could purchase a ipod cable that would not only charge but you would be able to control the ipod from the JVC unit. The part # KSU30 Crutchfield.com sells it for 39.99.
May 15, 2011 | JVC KW-AVX706 Car DVD Player
I have installed a jvc kw-avx726 and i just want to no which wire from the the head unit is the handbrake wire and also what do i need to make and answer phone calls through my cd player
http://books.jvc.com/booklist.asp?Model=KW-AVX706 This is a link to JVC support site where you can download the manual. However for a quick jump start. It is the LIGHT GREEN cable. Regarding the phone, reading the manual will be your best solution. Plus it is good to have a manual around. dreamsystems
Feb 08, 2011 | JVC KW-AVX706 Car DVD Player
Where can I find the user manual of JVC kw-avx726
http://books.jvc.com/booklist.asp?Model=kw-avx726
Aug 05, 2010 | JVC KW-AVX706 Car DVD Player
JVC KW-AVX 800 "Position error"
Assuming that this is not a new install (the laser is secured with a long, thin brass screw when shipped, and this screw must be removed on installation), and the unit has worked before today, then we will troubleshoot from the "damage" perspective.
The laser isn't centering itself to start position.
This could be due to track binding (dust buildup) or just a hard jolt to the base (pothole?), but the first thing to try is a soft reset...and if that doesn't get it, then a hard-reset next.
*Assuming of course that one of the kids hasn't jammed something foreign into the slot and knocked the head off-track...it happens quite often.
Soft reset:
Most models have a tiny, recessed "reset" button that you can press and hold for 5 seconds with a ball-point pen, located under the faceplate.
This will restore factory settings, and re-center the laser.
If the error returns, a Hard reset:
Disconnect the Positive(+) cable from the car battery for at least 30 seconds, and re-connect.
You will likely lose all saved stations on the radio, but this is a last-resort to avoid removing and opening the unit.
9 times out of 10 this will solve any digital errors, and will free sticky tracks better than half of the time.
Jun 29, 2010 | JVC KW-AVX706 Car DVD Player
Need to connect a pen drive and a ipod
u can get pen drive connector from india
Apr 14, 2009 | JVC KW-AVX706 Car DVD Player
JVC KW-AVX706 Car DVD Player Logo
617 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
