Question about Maxon MCB-40 40-Channels Handheld CB Radio
Maxon Model MCB10A
As confirmation this a mobile hand held transmit/receiver radio with a 3"X 1-1/2" medal box for the antenna and power supply connections. The unit does not transmit but receives fine. The SWR is okay. Trouble shooting suggestions would be appreciated. Don.
    Genius:
  • 1,139 Answers
In order to test this unit you will need a power meter with a dummy load. connect the power meter and turn on the unit, key the microphone and look at the power meter it should have a reading of < 4 watts PEP unmodulated and = 4 watts PEP modulated. If you do not have this reading the RF transmitter in the CB might be malfunctioning. You will need a RF generator, a power meter with dummy load, oscilloscope and a multimeter to troubleshoot this problem with. If you do not have or do not know what this equipment is or how it works, please take your unit to a CB repair shop. Thank you, Shuttle83
Posted on Oct 07, 2007
I have a icom ic-v8000 not transmitting or receving there is no short voltage everything looks perfect. when you key the hand held microphone all you hear is tweet,tweet, tweet......
The IC-V8000 is a high power (75 watts) 2 metre radio, it will draw about 15 amps on transmit. Also you might want to make sure your antenna SWR is low about 1.5:1. If you are not receiving anything at all I suspect you may have an antenna issue and this will also effect your transmit as well as the radio will protect its self by reducing the output to almost nothing if the antenna has a high SWR. If you don't have an antenna analyzer check with another amateur radio operator they may know someone who does. Your local amateur radio club most likely will have someone who help you solving your antenna problem.
Jun 29, 2017 | Icom Radio Communications
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
Motorola spectra ta9fw+078w will not transmit
There are a variety of reasons for your Spectra to fail to transmit. A few items to check would be:
1) Power to the radio. If enough power is not present, transmit is the first thing to usually fail.
2) Check your hand mic. This is a common failure part on a mobile radio.
3) Check your antenna and connections. Coax ages over time, and is not forgiving of creases or bends. Also, if your antenna stinger has become loose over time, it will effect your transmit.
Beyond the above mentioned items, most anything further would require repair of the component board of the radio.
Best regards.
Mar 04, 2012 | Radio Communications
My radio is not broadcasting reports.
Maybe its not transmitting because a Final Transistor has blown. Check to see if it receives well, change antennas,microphone...get a meter to measure SWR/POWER out. If it don't transmit or receive it may be seriously damaged. A final only cost several dollars if you know how to solder one in place. Its always like 2SC2078(Radio Shack carries them) it has 3 prongs to be soldered on the board with a heatsink and screwed to back with a ceramic insulator and heat glue. Swr over 2.1 will cause transmitter damage. Bad antennas,lightning may cause these problems. Get an antenna factory tuned at near 1.5 for 27mhz.Wilson 1000's,K40,Antron A99(18 ft.base) are good antennas.Look at www.copperelectronics.com for radio supplies,antennas and new radios.
Apr 20, 2011 | Radio Communications
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
The antenna base on my Maxon HCB-10C CB Radio got pulled out. Can I fix this?
Not sure what you mean here...
If the antenna is broke, then you should just get a new antenna. If the antenna connector was pulled out of the radio, it is usually fixable.
If the connector is broke off the antenna, it may may be fixable, I would have to see it. If its done wrong, you could hurt the transmit section of the radio.
You should just get a new antenna.
Sep 25, 2009 | Maxon HCB-10C CB Radio
Vhf 340 walkie-talkie radio you cannot transmit but you can receive effectively. I open the radio but no sign of any burn.I try the radio in all the channels is the same response. thanks. we use them in...
You may have a bad antenna. What happens is a lot of guys carry their radios around by the antenna, inside the connection to the antenna is weak and can crack at the solder joint, thus opening up the antenna circuit and prevent you from transmitting any power out. Our Motorola hand helds have this problem, they are weak at the antenna connector and guys swing them around by the antenna end up breaking them.
Your next problem is that if the radios have been used often enough with a faulty antenna circuit, your final amplifiers are probably toast from transmitting into an open antenna circuit, causing all the power to be reflected back into the radio and burning out the final amplifiers
Sep 15, 2009 | Motorola Walkie Talkies 2-Way Radio
Transmitting problem on motorcycle
  • Make sure you run the CB directly to the battery. What you are hearing is the alternator whining. Even then sometimes a low pass filter may be necessary. Make sure the chassis of your CB is grounded with a copper braid strap too.
  • Hope this helps.
Apr 27, 2009 | Midland 75-822 40-Channels Handheld CB...
BATTERY CHARGER HCB-30A CB MAXON
you can get that charger aftermarket at radio shack take the walkie with you to get the right power supply the voltage should be close to where the external power plug goes into the radio.
Mar 13, 2009 | Maxon HCB-30A CB Radio
Meter Shows Signal, no noise
when you have no RX or TX at the same time, that most often means the pre-driver audio transistor is bad.
Thanks,
Dodgem
http://dodgem250.angelfire.com
May 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Radio Communications Logo
201 people viewed this question
Top Maxon Radio Communications Experts
Van Allen II
Van Allen II
Mike Charette
eradiostore
eradiostore
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
