SOURCE: vw polo left indicator light stays on when lights are on
useualy it means that your tuns signal bulb is out on the front or rear
SOURCE: 2001 VW Jetta 1.8L - Front RH Door Lock won't lock
I have a similar issue on a 2001 Jetta sedan. jandkat seems to be talking about the old system that VW used (pre-1998). To my knowledge there is no vacuum-based locks in the 2001 models. I've had the door completely apart and there are defiantly not any vacuum hoses. The only 100% for sure fix I have found is to replace the door latch mechanism. There are some other options but I'm not sure they would completely fix the issues you are having. Now for the bad news: you can only get this door latch mechanism from VW dealers. I have yet to find a place online or elsewhere that carries them. They are around $185 for the latching mechanism and if you don't want to install it, be prepared to pay another $200 or so in labor. If you do want to do it yourself, here is a great site that has step-by-step how to take a VW door apart: http://forums.vwvortex.com/zerothread?id=1015107
Hope this helps
SOURCE: VW Passat 1.6l 2000 (UK) Electrical failure
fuses are usually in the glove box or under the drivers dash or under the drivers side hood either physically inspect every fuse by pulling them one by one or the aid of a test light and a good ground to the test light
SOURCE: volkswagen t5 caravelle central locking not working deadlocks on!
Turns out the problem was a broken wire at a junction below the carpet below the drivers seat. Took my mechanic 4.5 hours to fix it nightmare had to take seat out handbrake lever etc to get to it!!
SOURCE: Mk4 Golf. Remote locking, windows and interior lights not working
Maybe fuse number 6 is blown (check lefthand side of steerning wheel where all teh fuses are located - you must open the door)
