ASUSTeK COMPUTER Asus P5k Motherboard Green Rev 1.02g Logo
B
BISWAJIT SAMANTA Posted on Nov 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ASUSTeK COMPUTER Asus P5k Motherboard Green Rev 1.02g DRIVER
Lars Olsson
Level 3:
Brigadier General:
  • ASUSTeK COMP... Master 3,400 Answers
  • Posted on Nov 11, 2013
Lars Olsson
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1049072
Points
10330
1helpful
Asus P5k mono audio
Probably the Audio output socket is worn. They consist of a number of small sprung leaves and these can weaken over time.
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KEWIFIAP/#download
Manual #1:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3216_p5k-e.zip
Manual#2:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3501_p5k-e_wifi-ap.zip
How to wire the power cables to the motherboard
The motherboard manual will tell you where all the power connectors go, if you dont have it get it online.
Iwant my asus motherboard driver p5k-vm serial no:85moack11970 part no;90-mbb690-gouayooz p5k vm green
Here is a link to the drivers for your Asus p5k-vm Motherboard You will need to select the operating system you are using.
Please don't forget to rate this solution.
Asus P5k ethernet slot on motherboard just stopp ed working
Try tis...
1) Re-installing windows will not fix the problem. Try re-installing the
Ethernet driver (LAN). This driver should be on ASUS install cd.
2) Sometimes ethernet will just stop working. Then you should just
purchase a new ethernet card. They are rather cheap. Check out
Newegg website. You may have to disable onboard Lan in Bios.
The onboard ethernet card just stopped working. There is no fix I can find. I reinstalled windows and the drivers. once you instal the driver it only will start in safe mode.
Reboot your PC and hit F10 or F2 or any key it shows on your screen and go into BIOS setup and there should have one entry you can disable the onboard ethernet card.
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Top ASUSTeK COMPUTER Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an ASUSTeK COMPUTER Computer and Internet Expert? Answer questions, earn points and help others
