FixYa.com
Tags:
JVC AV-48WP30 48 in. Rear Projection Television
JVC AV-48WP30 48 in. Rear Projection (by 4 users)
posted by beemer328i on Oct 05, 2007
Hi Guys,
I have a JVC AV-48WP30 48 in tv and when i turn it on i dont get a picture or sound i can just hear a thump noise. sounds like the tv trys to start and the safty kicks in and stops it. the blue light dims alittle then brightens then dims ect...
I been hearing that this is a power supply issue can anyone confirm?
thanks guys
Comment by beemer328i, posted on Oct 31, 2007
Any idea what it could be?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by tgbaird1974, posted on Jul 03, 2008
Electricity went off for about 20 seconds, when it came back on and we turned the set back on all i got was a black screen and a thumping noise.
The power light just flashes from bright blue to soft blue.. Is there a reset
button on these tv's? I've tried unplugging and plugging it back up. Any suggestions on how to fix this problem?
Comment by bhubbs, posted on Jan 06, 2008
I just got the same tv and it has the same problem. i think that i am goin to try and replace the convegence board. the only problem is i cant find it. any suggestions?
Comment by becky1st, posted on Nov 26, 2007
I have the same problem
Best Solution
posted on Dec 06, 2007
Helpful (85)
sbrcatpuck
Rank:Guide Guide
Rating: 80%, 10 votes
this is the raw research for this that I have found. It seems like the most likely culprit for this is the stk chips on the convergence board (JVC didn't put nearly enough heat sink compound on should be a small layer all the way across they put on a couple dabs) I hear tale you can check this out by disconnecting the convergence board and turning on the set . only go after the convergence board from the front (behind the speaker grill is another panel, the convergence card is right behind there) there is a sneak circuit which will kick in possibly destroying at least the dvi input and mabie more if the set is powered on with the back removed and you didn't put a jumper in the right place or cover over a hole in the back of the dvi module (supposidly to keep people from hacking movies, like there arn't easier ways to do that if you really wanted to). if that doesnt fix it then I have found several other possibilities but I am now a few hundred miles from the tv that I was working on so havent had a chance to try this out:
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
JVC AV-48WP30 48 in. Rear Projection...
jvc av-48wp30
i have some problem with my tv... Answer This...
HORIZONTAL LINES ON TOP OF THE...
shows greenish horizontal lines... Answer This...
problem with your tv
I am having the same problem... Answer This...
JVC AV-48WP30 / convergence
I changed the ic's and the ohms... Answer This...
Problem on JJVC AV-32WFP1EK
I have a problem with my JVC... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
