Question about Kodak EasyShare DX6490 Digital Camera
Lens won't focus
The lens on my DX6490 will not come into correct focus. The auto focus mechanism is working but I think the lens may be out of position slightly. The camera was dropped and everything works except this. All the pictures I take are blurred. Can I fix this myself or if I have to get it repaired is it worth the cost? Thanks.
    Genius:
  • 2,985 Answers
It will be a repair shop job to do properly and will cost - lots So bearing in mind the the mechanism is very delicate and the drop may have wrecked it anyway you have nothing to lose I feel in trying very very gently giving the partially out lens a little tug- you cant break it worse thats for sure Try it--------- Then go buy another camera ;-}
Posted on Oct 07, 2007
SOURCE:
Pentax k200D auto focus manual focus button not working
Discover the location of the problem by elimination if you have a spare lens. If the second lens does not auto focus the problem is on the camera or connections to the lens. If the second lens works correctly then the first lens is faulty in the focus area. I hope this helps to target the source of the problem.
Apr 03, 2014 | Pentax Cameras
Canon lens won't focus
If it focuses OK in manual but not in auto then you may have broken ribbon cable in the lens.
Jan 20, 2013 | Canon EF 24-70mm f/2.8L USM Lens
Won't auto focus
Make sure the auto-manual focus switch on your camera is set to auto (A) and also make sure the auto manual focus selector on the lens is in auto (A) as well. If your lens contacts are dirty then this will affect the function of the lens as well. Clean those with either a lint free type cloth and alcohol or methylated spirits.
May 26, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My canon rebel XSi will not auto focus
Actually what I found to solve the problem was to first set the lens in "MF" and practice taking a picture manually to see if that would work. When I did this, I discovered that the fine tuning portion of the lens was somehow stuck mechanically. I heard a loud click as I turned it. That was all it took to fix the focusing mechanism on the lens. Then I set to "AF" and Voila, the camera worked just fine.
Apr 04, 2010 | Canon EOS Rebel XSi Digital Camera
Lens will not auto focus any more.
Hi there!
I experienced the exact same problem with my 100-300mm lens and I was never able to get it to work correctly again. In fact, attempting to use it further seemed to exacerbate the problem.
The further you zoom, the wider the aperture opens allowing more light for the camera to focus properly. If the aperture mechanism is damaged, the auto-focus process may not work as it should; which would explain why the auto-focus feature works only when at 18mm.
Regardless, I strongly recommend you discontinue use of the lens until a professional technician can examine the lens and figure out what's going on. I'm sure you can contact the manufacturer to open a support case or you can find a camera store that offers repair services.
I hope this helps!
Aug 29, 2009 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
The Autofocus does not work on my Nikon D40
1 Possiable dirty lens contact terminals
2 Auto focus motor in lens is jamed/malfuntion
3 Auto focus engagement pin on camera body is not engaging the lens
4 Correct lens,old nikon lens and some 3rd party lens wont work on the D40
Jul 18, 2009 | Cameras
Nikon D300 When I depress the shutter half way or fully on my D300 the frame counter reads r27 and the lens (any previously compatible Nikkor lens) will not auto focus. The camera is not set in burst mode...
Only reason the lens will not auto focus when you depress the shutter half way is due to either lens AF switch is set to Manual OR camera body's focus system is on M. There is 3 way toggle switch below the synch port around the lens mount. It should be set to C or S in order for auto focus to work. If all the settings are correct and even "AF-ON", next to rear dial doesn't activate auto focus then the issue maybe in the setting or the body itself. As for the buffer reading r27, I think mine displays r## regardless of burst/continuous mode.
Jul 13, 2009 | Nikon D300 Body Only Digital Camera
Want to buy a dx6490 outer lens
if you cant swap one yourself from a dead camera it would be beyond economical repair.
If you are adventurous you could buy a faulty one of ebay and swap the lens or if the faulty one has a broken screen or mode dial swap yours over to the faulty one..
there are a couple of "tricks" do getting this camera open drop me a line if you decide to proceed...
best of luck
Apr 10, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
129 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
