Question about Maxtor (6L250R0) 250 GB Hard Drive
Drive not spinning, or being detected
I tested for every possible problem, even flashed my BIOS and my new Maxtor 250GB HDD is not being detected. It makes noises like it wants to start spinning, but it stops a split second later with a click like a spring loade plastic pin is being released. Then it starts the same thing over again almost a second later. My mother board is functioning properly, I even tried switching to the secondary IDE controller and still nothing. I have tried every possible jumper position imaginable and still no dice. Is there hope, or was it DOA?
  • watzmp Feb 15, 2009
    very same problem
  • brown2671 Apr 14, 2009
    my maxtor 250 beeps & is not recognized by my computor.Fixable?
I had got the same problem. You should use 3 vertical jumpers on the left side for Master position
Posted on Nov 01, 2007
I had got the same problem. You should use 3 vertical jumpers on the left side for master position
    President:
  • 317 Answers
Since it's a new drive, I would return it for another one. Sounds like it is DOA.
Posted on Oct 05, 2007
SOURCE:
HDD NOT WORKING PERFECTLY
I'm confused. Is the maxtor drive 250GB? Have you partition it to 30GB? Or is it that the computer only reads 30GB instead of 250GB? Does this drive have Windows on it? Also you might want to check your BIOS (Motherboard input/output system) by pressing Del key or F12 and see if this drive is the startup Drive. If you don't have Windows on this drive, make sure it is NOT the startup drive. Hope this helps.
Dec 09, 2013 | Maxtor Hard Drive
This drive 250gb hitachi is not being recongnised by my computer.
maybe its in the bios settings that set to first boot was your external hdd,,,open bios settings and set first boot to harddisk drive,to boot your primary hdd so your external will be now detect
Feb 12, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Hard drive does not operate
1, switch off computer
2. remove side (usually two screws on the back held it)
3. remove and then re-insert power cable from hdd
4. remove and re-insert data cable, from hdd as well as from m/b
5. start computer and hold your fingers on the top of the affected hdd, if you feel vibrations, this meant that driver is spinning and therefore rescue can be attempted at home.
6. research and purchase hdd recovery software, follow it's instruction and save data on another medium, be it another hdd or cd's dvd's.
if there is no spin, recovery is still possible but in specialist lab and will cost more money....
always back-up your data, second hdd is much cheaper than data recovery from existing one...
Jul 27, 2010 | Maxtor Hard Drive
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Maxtor One Touch III 200GB Drive stopped spinning. Light is on. OS doesn't recognize it (Win 2000 Pro).
first you ensure that it is detected or not in BIOS. if it is not detected then cable may be faulty otherwise HDD is faulty.
Aug 21, 2009 | Computers & Internet
Hard drive goes on blue light go around once pc
Tried to boot the computer in bios. Check if the harddrive is detected in bios. If not detected. Shut down the system,take out the power cable.open the tower and disconnected the hdd IDE cable and connect it to a differnet IDE port. Restart the system and boot in bios check if hdd detected. If still not detected possible issue with hdd. Try connecting on different computer if still issue persist replace Harddrive.
Aug 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Suppend HDD sunddenly can't detect
nahh sounds like bad pcb board of hard disk. check in bios to see if its detecting hdd.
if it is then id say try ubcd4win.com to boot pc with or without hdd to test pc and ram.
sounds like an old hdd.
Jul 22, 2008 | Maxtor Hard Drive
Dear noggin
is the jumpers set correctly . to slave or try cable select
Mar 02, 2008 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Maxtor (6L250R0) 250 GB Hard Drive Logo
373 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
