Question about Panasonic PV-DV953 Mini DV Digital Camcorder
Mpeg recording to SD card
I'm using my PV-DV953 to monitor property to catch a thief in a remote outdoor location. I'm mpeg recording to an SD card. The camera always shuts itself off at exactly 2 hours, even though the card and the power have ample capacity to last all day. Is there any workaround for this?
  • 2 more comments
  • Will-T Oct 05, 2007
    Sorry, that doesn't help. The manual says on page 71, referring to MPEG4 recording, that "more than 100 hours of remaining time is indicated as [R:99h59m]." This clearly infers that long MPEG recording is possible. I can't find any reference to a run time limitation of 140 minutes for the camera. The manual does say on page 44 that the camera will stop recording at 120 minutes when the card capacity has been fully utilized. (This being relative to the 16mb card that was supplied). I'm using 1 gb card with battery capacity of not less than 10 hours - but I still can't get past 120 minutes. I need a workaround.
    Does anyone know what I can do to make this work?
  • Will-T Oct 06, 2007
    Did the test - watched how it shut down. No message appeared prior to cessation at exactly 2 hours and 0 minutes. Recording simply stopped. The MPEG indication on the display changed from red to blue, and the timer display stopped running up. 7 minutes later the camera powered down altogether. (This power down function is normal when there is no recording activity - no surprise with that.) Still need to know how it could be possible to keep it recording all day (or until the card is full or power depleted).
  • Will-T Oct 07, 2007
    Back to my question. Does anyone know of a workaround to allow MPEG recording to run all day unattended. For example, would attaching a perheperial or changing set-up settings make a difference? Can the web cam feature be used to record to an SD card somehow?
  • 752 Answers
Set it up on your kitchen table (or somewhere that you can monitor it..) and do exactly what you do when you're using it at the location and note the time. When you get to about 118 minutes, hang out by the unit and see what it does when it hits 120 minutes. It should give you some sort of indicator as to what it's doing (for example, the screen might flash "memory full" or "low battery" before it shuts down, thus directly telling you what's going on). Report back here with the results of this test and we'll go from there.
Posted on Oct 05, 2007
  • Mitch
    Mitch Oct 06, 2007
    Ok, I've read the manual and I've got it. 120 minutes is the MAXIMUM recording time PERIOD. If you look on page 44 where you found the reference to the OEM 16MB card it lists the maximum record time for IT as 15 minutes. It appears that the 120 minutes is regardless of card size. Sorry to be the bearer of bad news! :(
    President:
  • 2,961 Answers
This may have something to do with the fact that the camera powers down before the battery is exhausted as the maximum run time is 140 mins which is roughly the time you say it stays on for.
SOURCE:
I want to record from my Lenovo ideapad camera in private so no one knows as I need to catch a thief
You could turn the screen off and leave the laptop recording or use Skype and monitor the room from another device.
Jul 08, 2016 | Lenovo Computers & Internet
Panasonic PV-DV953D video transfer to PC
Did you put the camcorder in the VCR mode and make sure it is turned on, so you can transfer the video?
Jul 30, 2008 | Panasonic PV-DV953 Mini DV Digital...
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
It presents an error called DEW Detected and it shuts down
The unit is wet or it is too humid to work properly. Try to move the unit to a dryer location so the moister can evaporate.
Aug 13, 2010 | Panasonic PV-DV953 Mini DV Digital...
My lexar sd 4G card won't work in my camera? says card error in card record mode?
The PV-GS36 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it will not work properly. You need to use SD cards, 2GB and smaller.
May 23, 2010 | Panasonic PV-GS36 MiniDV Digital Camcorder
Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
Feb 10, 2009 | Panasonic PV-GS500 Camcorder
Red lines on screen when recording
Important Notice
Digital 3CCD Camcorder
Panasonic has discovered a premature component failure with a limited number of PV-DV953 (2003 Model) and PV-GS200 (2004 Model) 3CCD camcorders, which may cause an abnormal camera picture (incorrect color reproduction, reddish, noisy image, etc). This anomaly is limited to a specific range of serial numbers listed below.
If your camcorder demonstrates the specific symptom and falls within the serial number range, Panasonic will repair the camcorder free of charge.
Please call the following toll-free number for assistance in receiving a free repair:
Panasonic Call Center: 1-800-973-4264
Model # Serial Number Ranges
PV-DV953 (2003) E3Hxxxxxx, F3Hxxxxxx, G3Hxxxxxx, H3Hxxxxxx, I3Hxxxxxx, J3Hxxxxxx, K3Hxxxxxx, L3Hxxxxxx and A4Hxxxxxx
PV-GS200 (2004) C4Hxxxxxx and D4Hxxxxxx
Nov 19, 2006 | Panasonic NV-GS200 Mini DV Digital...
Storage path
On removable memory cards. Panasonic iPalm Digital Cameras are equipped with an SD Card Slot which allows the camera to store images on EITHER an MultiMediaCard (MMC) or an SD Memory Card. Simply insert an MMC or SD Card into the camera, take pictures until the card is full, then remove it or replace it with a fresh card. You can selectively erase any or all of the images from the either the MultiMediaCard or the SD Memory Card and reuse it. Storage capacity for the PV-DC3000-A (based on included 16MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 13 images Fine Mode (2048x1536) up to 27 images Normal/2x Digital Zoom Modes (1024x768) up to 69 images Burst Recording Mode (1024x768) up to 82 images 3x Digital Zoom Mode (640x480) up to 150 images Motion Image Recording Mode (12 sec. max./320x240) 9 sets TIFF Mode (2048x1536/no compression) 1 image Storage capacity for the PV-DC3010 (based on included 32MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 29 images Fine Mode (2048x1536) up to 57 images Normal/2x Digital Zoom Modes (1024x768) up to 145 images Burst Recording Mode (1024x768) up to 172 images 3x Digital Zoom Mode (640x480) up to 315 images Motion Image Recording Mode (12 sec. max./320x240) 19 sets TIFF Mode (2048x1536/no compression) 3 images
Aug 31, 2005 | Panasonic iPalm PV-DC3010 Digital Camera
Storage path
Aug 31, 2005 | Panasonic iPalm PV-DC3000 Digital Camera
Panasonic PV-DV953 Mini DV Digital Camcorder Logo
99 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
