Question about Dell 3100cn Laser Printer
Printing CMYK dots twice on every print
Printer has been great for two years. All of a sudden it's printing two little strips (like a 1/4inch) of CMYK dots (one of each color) at the top of each printed paper and in the middle. Haven't been able to get them to stop printing despite multiple prints and wiping down the inside. Not sure what else I can try to do.
  • RyanCD Jun 20, 2008
    Hi Kate30's,
    I have the same problem. I clean the fuse drum and clean the toner drum and reloaded all the ink cartridges The problem still exist. What did you do to fix this problem? Thank you.
  • Anonymous Mar 24, 2014
    it prints wonderful but last night it had a little red button that stayed on |_|
I had that problem and had to replace the drum. It was expensive,b ut did the trick for me.
Posted on Feb 03, 2009
    Problem Solver:
Did any of the suggestions help with this problem for any of you?  I'm having the same trouble, and the fixes here haven't helped me
Posted on Oct 26, 2007
  • 106 Answers
Cleaning of the Fuser drum will solve the problem
Posted on Oct 07, 2007
  • 163 Answers
Clean the drum with propyle alcohl
    Scholar:
  • 191 Answers
Hi, As it's printing two little strips (like a 1/4inch) of CMYK dots (one of each color all you need to check the toner cartridge drum, try to wipe the toner drum with a damp cloth on each color cartridge. Secondly check the fuser assembly drum if it has any mark on the drum, try to use a mild isopropyle alchohol to wipe the dirt mark them try printing. this will resolve the issue. if still issue persists then change the color cartridge one by one. This will definitely resolve the issue.
Posted on Oct 06, 2007
SOURCE:
Grievance
Do the colour prints when printing RGB look all right?
If so, the printer is working.
What sort of CMYK are you trying to print? CMYK EPS prints, maybe?
If so, the the fault is one of not using the correct software; the printer is working, it is just not interpreting the encapsulated PostScript to reproduce a CMYK image. Use different software capable of reading CMYK EPS files. Photoshop is one such piece of software.
Dec 12, 2013 | Office Equipment & Supplies
CMYK dot problem
can be solves by changing whole drum unit because problem with bias grid (black strip on chager)
Jul 02, 2009 | Xerox DocuColor 12 Color Copier
Black and Magenta ink won't print...
Do a deep clean on the printer.
Done from the printer setup.
widows is done from start, printers and faxes, click on your printer.
Should bring up window for setup.
Look for cleaning section.
May 07, 2009 | Epson Stylus C88 InkJet Photo Printer
Publisher cannot print this publication. To print composite CMYK or separations, you must use a printer driver that is set to output PostScript language level 2 or later.
your printer and it's driver is not PostScript capable.
what you can do is, change your Publisher document setting to RGB, all inkjets use RGB.
CMYK is used by Printing Press
Dec 13, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing special effects from corel draw on Eltron p310
Try looking for an option in printer driver Graphics settings which prohibits black panel printing
Nov 15, 2008 | Zebra Eltron P310 Thermal Printer
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Creating Halftone Dots
in photoshop you can use a filter to create dots you can actually see on screen, cant remember exactly where it is, but it is in the filter menu. Also to print halftone dots you hit print and go into the print preview dialogue box, click on the screens button. another dialogue opens uncheck use printer defaults. This allows you to specify what frequency angle and dot shape you would like for each color you are printing. By default CMYk are specified for the layers visual space, other spot colors can be added using channels and will show up within this dialogue along with CMYK options. however, you can only have one channel selected at a time to get it to print correctly.
Similarly in illustrator, the options are in the print dialogue. detailed info about each of these processes can be found in the help menu of the respective programs. you may want to check out this link. Many of these questions are answered in this forum all the time. http://screenprinters.net/articles.php
Sep 13, 2008 | Adobe Photoshop 7.0 for PC
3100 Dell Printer - Printing CMYK DOTS TWICE ON EVERY PRINT
We had a Dell Engineer come out for this prob and it basically involved replacing every working part inside it until it worked! :-(
He said he believed that it might have been toner leaking out, but I don't believe that because of the precision of the dots on every printout.
I hope urs is in warranty!
Jun 20, 2008 | Dell 3100cn Laser Printer
Printing CMYK dots twice on every printposted by RyanCD on Jun 16, 2008 Report abuse I clean the fuser drum and wiped clean the toner drum and took out the toners and put them back in. The dots still show...
If you are getting single color dots but all 4 colors the issue has to be somewhere comon to all 4 which usually is the Transfer Belt. i would look for some sort of damage to the belt or something sticky on it.
Dell 3100cn Laser Printer Logo
490 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
