Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Power and sound turn off after 15 minutes
After 15 minutes the power and sound automatically shut off. To turn back on I have to unplug the TV and plug it back in, and then the green light automatically comes back on without pushing the power button. It was supposedly repaired a week ago - some contacts were soldered, but has started to do it again. Anyone have any ideas.
  • 3 more comments
  • 20cents Nov 13, 2007
    I have the same problem with my LCD tv. It's new and I thought it was the satellite receiver but the tech came out and replaced the box and it's still doing the same thing. The tv manufacturer's phone tech support had me unplug the tv for 3 mins to clear the memory from the motherboard of the tv unit and that worked for about an hour tops. Still not fixed...Please let me know if you fixed yours!
  • anf2004 Mar 16, 2008
    switches off every ten minutes when watching through sony dvd hd box and ps3. owned it for one day already gettibg problems, please help
  • benie808 Mar 30, 2008
    i have the same problem .. its irratating when its off automatically and went to standby.. theres a red light blinking.. i tried your solution that you given and u said count the red light when its blink.. i counted mine and 6 (blinks). please help me i dont want to call someone who is takin so long to fix my tv back..
  • beau_f Dec 02, 2008
    Same problem but my red light blinks 9 times. Tech already replaced power board. Went out an hour after he left. Supposed to replace lcd panel next but he is just guessing! Any info would help!
  • Anonymous Mar 28, 2014
    The Regulated 12 volt and regulated 24 volt supplies are both good. So are the 3.3 volt stand by voltage and the unregulated 15 volt supplies. The power light comes on and stays on but there is no picture, and the power button won't respond. If i unplug it for a couple of minutes, it all works fine untill i power it off and on without waiting for it to discharge enough. Any ideas?
  • 43 Answers
Is the red light blinking in the front of the tv. Counnt the blink sequence then I can give you more info.
Posted on Jan 05, 2008
TV - Mitsubishi WD-62530 Will not power up unless first unplug from wall for approx. 15 minutes prior to turning it on or it will not power up at all).
Start with changing the capacitors that look bad on the PS board...I think you will find some that are bulged when you take the cover off, should be a easy and cheap fix
Oct 22, 2017 | Mitsubishi Televison & Video
Samsung TV shutting off by itself and relays clicking
If you don't know what you're doing, don't open it up to fix it!
There are HAZARDOUS voltages on the power supply board EVEN WITH THE TV UNPLUGGED!!! The capacitors can hold a charge for several weeks!
Clicking noise can be coming from bad capacitors on the power supply board.
It's usually easier to just replace the power supply board.
Sep 09, 2016 | Samsung UN55B8500 TV
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
TV wont stay on longer than 15 minutes
Sounds like your power board is shutting down as it gets hot. I would get prices for and replace the power board!
Mar 18, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
TV turns off
It sounds like you might either have a bad power cord or you might have an over heating issue. Some times the TV will automatically shut off if it senses a fan issue or it starts to overheat. What technology is your set? DLP, LCOS, DILA...? If its under warranty I'd suggest to get someone out asap to take a look at it.
Sep 13, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
379 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
