Question about Acer n30 Pocket PC
Acer n30 problem with expansion slot.
Hi i have an acer no30 and there appears to be a problem with the expansion slot, u put the memory card but will not stay in just keeps coming out, occasionally u can get the memory card to stay in but not very often, if you press on the left hand side of the pda(with screen looking at u)it makes a noise and shows up in the file explorer programme but wont stay in or very occasionally. have took it in to comet for them just to have a look at but they were not very helpful and will charge me £50.oo just to look at it. could u possibly help at all.
    Scholar:
  • 151 Answers
The spring lock needs to be adjusted, you need to open it to make it work again. Although if you want to try a nifty trick I do with cards spitting out in the slot is to put a square-cut electrical tape on both sides of the sd card and it will stay in...
Posted on Dec 10, 2007
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
https://www.greatcall.com/docs/default-source/pdfs/jitterbug-smart-user-guide.pdf
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
May 19, 2017 | Cell Phones
Can you replace the memory expansion slot in an acer 5315
Not easily Scarlett. You need a REAL computer tech to perform this, and there are very few of us left. (lol!)
May I suggest this?
http://www.laptoprepair101.com/laptop/2008/02/28/fix-laptop-memory-slot-failure/
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 29, 2013 | Acer Aspire 5315 Notebook
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
(Top right of your page, blue Comment)
Regards,
joecoolvette
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Wot is the memory card slot for
HI,
The memory slot is an expansion slot that you can put a camera card (SD card) into so you save all you photo's to that instead of the internal memory.
This is because your camera only has a limited amount of internal memory limiting you to the amount of pictures you can save on the camera.
Purchasing a memory (SD card) is certainly an advantage and they can be used in card readers, MP3 players and computers etc.
Regards.
Sep 14, 2009 | IT Works Cameras
I just bought a new memory card for my pc how do i fit it
You can follow this link and view the video for the same.It has acer aspire memory video as well.
Hope it helps !!
Thanks !!
Sep 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
HP Color Laserjet 2840
There is only ONE SLOT for expansion memory for the HP 2840. The slot is located behind a cover on the right side of the machine looking from the front. Once you remove the cover you will see the one and only slot available for printer memory expansion. The slots on the front top corner ARE NOT for printer memory expansion but rather for different styles of photo/camera memory to off-load pictures etc...
If you need the printer memory cheaply (about $25.20 for 128MB) go to www.memory.com. They have it in stock.
Hope that helps you. If so, please rate me with a FIXYA. :) If not give me a yell and I'll help you further.
Sep 29, 2008 | HP LaserJet 2840 Printer
Acer n30 wlan card
If your router has wireless broadcasting. Check all the settings in your router. Add the MAC address of the WIFI Card to your routers Wireless settings and also maybe in your firewall settings in the networking of your router. Be sure to add the WEP key when you connect to your router. Check your security settings.
Aug 26, 2008 | Acer n30 Pocket PC
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
Acer N30
I can't believed it. Solution couldn't be more simple!
At Device Manager where it appears with exclamation mark, just click Update Driver and then choose Install the Software Automatically.
Windows can find it.
Oct 02, 2007 | Acer InviLink 802.11b (91.49C10.002)...
Acer n30 Pocket PC Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
