Question about Microsoft Windows XP Home Edition
Computer Monitor My computer monitor does not work , but the tower is ok. When I switch on the monitor it turns red and switches off in a matter of moments...
    Problem Solver:
  • 15 Answers
Check your slot of your video card, make sure it is good stand position
Posted on Oct 06, 2007
    Problem Solver:
  • 7 Answers
Sounds it may have a short in it or your cable. Try replacing the cable, if that doesn't work, try to get another monitor and see if it does the same thing.
Posted on Oct 05, 2007
SOURCE:
Red light and green light on AMD 64 Athlon x2 and locks out monitor
Processors do not have monitors. Or lights for that matter. What monitor do you have and is the button you hit on the monitor or your computer tower? Are the lights on the monitor or the tower?These are important questions, don't you think?
Apr 04, 2013 | Computers & Internet
Hp t450 desktop won't turn on
is there a reset button anywhere on it
Dec 05, 2011 | HP Computers & Internet
We have a samsung syncmaster p2050 monitor and a dell tower but the screen does not stay on to enable you do anything pls help to identify if its a monitor problem or a dell problem?
At a guess it's probably a monitor problem but the only way to be sure is to test the theory.
You need to beg, borrow or steel another monitor and connect it to your tower, if it works Ok, your monitor has the problem, if not, its your graphics card.
Or, if you can't borrow a monitor, ask if you can connect yours to a friends tower or even a laptop with a vga port on the back (blue 23 pins).
With the laptop, you should be able to switch between the laptop monitor and the ancillary monitor by pressing the "Fn" and another key (look amongst your "F" keys and your Number keys, there should be a picture of a screen). Don't forget to switch back by pressing the same keys again.
Aug 19, 2011 | Samsung P2050 Monitor
I have a dell E228WFP 22 in monitor.The power button does not work therefore I have to leave monitor on at all times.Cam i get this repaired?
These monitors are switched by a signal from your computer. When this signal is present, the monitor turns on, when you shut your computer down, the monitor turns off. In the meantime it remains in "stand by" mode. The main moitor switch should turn if off alltogether. If it doesn't, the swich can be replaced, but cecause these are "momentary" switches it's not an easy thing to do.It won't matter a lot if you don't replace it.
Mar 29, 2010 | Dell E228WFP LCD Monitor
I had to take my computer in for repair and turned the acer monitor off while the tower was gone. After plugging everything back in after repair, the monitor will not come on when you hit the power...
The first thing to check is , the Power, are ya sure it's plugged in OK, are ya sure that socket is working, try something else in that outlet to prove, check the power cord is pushed right in, Check ya on the right Video connector on the PC, make sure all conns are correct. Try the monitor on another base unit, try your base unit on another monitor. If all these are OK then ya Monitor has turned it's toes up sorry.
Jan 20, 2010 | Acer AL1914 19" LCD Monitor
ViewSonic VX910 monitor appears to have power supply issue. The power light comes on for less than 1/2 sec, then goes off for about 1 sec, then just flashes green. If you play with the switch and the A/C...
try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Jul 01, 2009 | ViewSonic VX910 19" LCD Monitor
Monitor rejects computer
I'm just guessing, but it could be that the resolution you are using on your MS-DOS monitor is not compliant with the new monitor you are trying to use. Check the supported resolutions of the monitor that you would like to use, and then make sure you set that resolution before switching monitors.
May 10, 2009 | Computers & Internet
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Black Screen
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Feb 08, 2008 | Sony VAIO VGC-V617G PC Desktop
Microsoft Windows XP Home Edition Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
