Question about Sennheiser E835 Professional Microphone
E835 distortion My fairly new (at the time) e835 mic started sounding poorly (distorted) way to soon in its pampered life. Is there anything that can be repaired/replaced for considerably less than the cost of a new one? Thanks
How to replace a cap most, without resorting to the help of the service-centre (to take out it-cap from the case) wire dynamic microphone Sennheiser e845
Posted on Mar 27, 2014
  • 682 Answers
It is very good brand first try to get ride off humidity and wet by putting it with some rice in plastic box and leave it for a couple of days(rice absorb wet and humidity).if it is not working good change the mic capsule.
Posted on Mar 01, 2008
6ya staff
SOURCE:
My e835 goes dead occasionally during performances. It's always on a Mic stand which is stationary. Suddenly there's no sound. If I unplug the cable from the mic and plug it back in it works again. I've...
I'd undo the set screw and very gently pull out the connector just a bit from the body and clean up the 3 xlr leads with a fine handheld (available at any car parts store) brass wirebrush or fine steel wool. You can also buy a product/kit from Caig Labs called De-Oxit and just apply it with the little brush supplied (with kit) or a foam (not cotton) swab instead of opening it up.
Nov 15, 2017 | The Audio Players & Recorders
Complaint with the poor quality of Pampers Nappies
not a fixya site problem
get the company web page up, use the contact section and make you complaint directly to them
Jul 07, 2017 | The Office Equipment & Supplies
Are e835 mics okay on a system using phantom power?
If the microphone is ballanced there is no problem. Only XLR unballanced would be a problem.
Jul 16, 2011 | Sennheiser E835 Professional Microphone
What is the best setting EQ wise for a Sure beta 58A and a Sennheiser e835 mics? I have the HA120
Always start with flat setting. Be careful of boosting highs as feedback may be a problem Put the speakers forward so mics can't "hear" them.
Apr 06, 2011 | Harbinger HA120 Portable PA System
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
When i plug the microphone into my amplifier it works fine... but when i plug it into my computer using a 1/4" to 1/8" converter it has no sound on audacity ..im running vista on a 2008 hp laptop...
The 1/8" input is expecting "line level" for the audio. The mic generates "mic level" which is much lower. In order for this to work as you'd like, you need to have a mic preamp in the system. The typical way to do this is to use the output from a mixer rather than from the mic directly.
Dan
Dec 28, 2010 | Sennheiser E835 Professional Microphone
Need replacement cage (around windscreen) for sennheiser e835
local music store probably carries aftermarket mic grilles and most microphones anymore have standard threads.
or you can go to online music equipment sources and search for microphone grille and look for one that would fit.
Dec 03, 2009 | Sennheiser E835 Professional Microphone
Sennheiser e835 wireless mic won't turn on
how long did you hold the on button for? press it longer
Mar 02, 2009 | Sennheiser E835 Professional Microphone
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Rode NT1-A Distortion on "S" sounds and plosives
This is typical component failure. The mic will require professional service. Condenser Microphone Mod Service
Nov 01, 2008 | Rode NT1A Professional Microphone
Sennheiser E835 Professional Microphone Logo
273 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
