Question about Sony XM-2100GTX Car Audio Amplifier
Sony XM-2100GTX Car Audio Amplifier sound but very low
Driving along to work and the bass like died, pulled over and there is sound coming from my 15 inch sub but no big bass? all lights are on, cap, working any ideas
  • 4 more comments
  • markus223 Oct 09, 2007
    Tryed another sub exacly the same and the bass is there but further into the song it disapears and comes back when it wants to , the bass stays on at the beginging of the song then dies through it ? the amp isn't hot and all lights are on as normal?
    it happens when driving and Stationary, i'll try the RCAs when i get home,haven't got any spares but i'll ask around, how can you tell if there damaged,
    thanks for help so far :)
  • markus223 Oct 11, 2007
    i've tried another sub smaller this eveing and it doesn't cut out but this is a infinity 1200 w sub the original sub was a 1500 w which works in my mates car with sinalir power amp. , but i've noticed my Farehd cap which is a toxic 1 Farehd  cap the blue lights go off after while is this normal  after the turn the key. i've checked rca wires and i've checked and turned the switches on the amp but seems to work with smaller sub but bigger sub the problem continues?
    thanks so far :) really been great thanks
    how would i find that out ? im a novice at all this lol sorry if it sounds stupied lol
    my sub i have the problem with is Toxic TSW150F
  • Anonymous Jan 19, 2009
    very low sound coming from two speakers
  • 631 Answers
If there is sufficient voltage at the amp, you may have blown the woofer. If you have another speaker, connect it to the amplifier to see if it plays normally. If not, the amplifier may have failed. Let me know what you find.
Posted on Oct 05, 2007
  • 2 more comments
  • Anonymous Oct 09, 2007
    If you have another set of signal wires (RCAs) going to another amp, use them to drive the sub amp to see if the problem remains.
    Does the problem seem to be related to shock/vibration (does it cut off when you hit a bump)?
    Moving the signal cables from the highs amp to the sub amp will send a known good signal into the amp. I'd suggest that you use the cables that were plugged into the highs amp. You know that they are in good working order. If the amp still cuts out, it's likely in need of repair.
    One other thing you can try is moving all of the controls on the amp. Sometimes a bad connection in a switch or pot can cause similar problems.
  • Anonymous Oct 11, 2007
    What's the impedance of this woofer?
    What's the impedance of the 15" woofer?
    Some capacitors shut off automatically and some have a remote terminal to switch the display off. If yours doesn't have a remote terminal, it should shut off after the ignition is switched off.
    The easiest way is to measure the resistance with an ohm meter (with the speaker disconnected from the amp).
    Otherwise, you'll need to know if it's a single or dual voice coil woofer. If it's a DVC, you'll have to know if the coils are in series or parallel. You'll have to know the impedance of the individual voice coils. Sometimes the exact model of the woofer will tell you whether is a SVC or DVC and the impedance. You'd have to pull the speaker to determine if the coils of a DVC woofer are in series or parallel.
SOURCE:
Sony XM-1600GSD have low amps on middel fues and wont work
You are in over your head with this. There is only one fuse on the outside and it is the main power fuse. When you hook something like this amp to a power source for conversion from 110 there is a ripple current. The more the Sony pulls out of the converter, the higher the ripple current came be. That ripple can cause failure of other parts in the amplifier. Since you heard a pop sound. It is apparent that the components in the amplifier have failed. You are going to have to disassemble it and look for damage. Then you need to find that parts that are blown and then you need to be able to solder and replace them.
Nov 12, 2017 | Sony XM-1600GSD Car Audio Amplifier
I purchase sony cdx-gt49um but very low bass & av. sound qulity what can i do to improve?
Nothing sony is a good name but when it comes to car audio they have nothing but their name. I had a thump amp from the 80's that worked better than my sony xplod that had more power. If you want better quality try rockford fosgate, clarion or kenwood
Mar 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Problems with my sony xm-2100 gtx amp
check your wires and your ground wire it might be touching something causing it to spark and your amp to go on protect mode also check your fuses..also sometimes this works put your db and all your settings on your amp low as it can go sometimes its just to much power n hits like an impact.
Jun 09, 2009 | Sony XM-2100GTX Car Audio Amplifier
Sony XM-1652Z
What head unit do you have?
Is there a dedicated subwoofer output?
If not, have you switched the rear output to sub output?
Is the amplifier set to LPF (low pass filter), and the gain turned up?
Many things can be wrong, but the fact that there is anything coming out of the subs is a good thing.
Start at the beginning - Head unit, then check amplifier gain/crossover setting.
If you are using a hi level adapter on factory radio, is the Bass on the radio up? is the output gain on the convertor up?
Jan 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony amp
I simply ran my remote wire to the 15amp fuse for the vehicles radio,that didn't work so i tried drawing enough power from a speaker wire(all @ the advice of my brother)but i got the same results, it just won't shut off.
Jan 19, 2008 | Sony XM-2100GTX Car Audio Amplifier
Sony XM-2100GTX Car Audio Amplifier Logo
247 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
