Question about Panasonic DVD-CV35 Multi-disc DVD Player
Panasonic DVD player--skipping
It usually plays a DVD for about an hour and then goes nuts, gets "stuck" and skips etc. Sometimes it plays a whole movie no problem, sometimes it won't play at all. And it's not the discs; they play fine in another player, laptop, or even PlayStation. Also, if I can't fix the Panasonic, someone gave me a little portable player (Daewoo DPC-8400N) and I'm wondering if it can be connected to a television? I seem to recall reading that on the box...but I no longer have the box...and haven't been able to find a manual or any info online. This site is telling me it's not a valid product! LOL! Thanks
SOURCE:
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
satavlad
  • 405 Answers
SOURCE: we have model dvd changer dpc-6.1 It skips part of
Problem is a DVD mechanism, if you are capable replacing it by yourself it make sens to repair the unit. I've seen parts here.
Posted on Dec 02, 2009
  • 208 Answers
SOURCE: I have a Panasonic DMR-EZ48V and have had many
sounds like total hogwash to me. Your description of the problem smacks of an internal error within the unit itself.
this is not exaustive but could lend itself to a buggy firmware upgrade or a noisy power supply problem which is causing the microprocessor to "Hang".
There is many forums including this one with the same lament as yours. It is widely known that power supplies in the panasonics are under engineered and have a tendency to overheat and cause many problems including rebooting, constantly "self checking", etc.
My suggestion is to take the unit to another "accredited' Panasonic Service agent and get a second opinion - Good Luck
Posted on Mar 18, 2010
  • 10 Answers
SOURCE: Iwant to buy cables for
MAPLAIN
Posted on Feb 06, 2011
Dvd get stuck 1 hour into film
There MAY be contamination of dust on the lead screw that moves the head. Be VERY careful cleaning as the head is suspended on flexures that are moved for the fine movement necessary to follow the tracks on the disk.
You might want to take this in to a repair shop and see if they can clean it.
Replacing the drive would likely cost the better part of the original cost of the whole unit.
Dec 13, 2009 | Sony RDR-VX555
CDG or DVD skips
I came here hoping to find a solution to the exact same problem. I also used the CD cleaning discs. Had the same result. Works for a while, then it just does the same thing again. Problem is, I have a party tomorrow. We are planning on using the Singing Machine STVG 718. (That's the name of my machine)
Mar 08, 2009 | Denon AVR-2106 Receiver
Dvd pixilating and skipping about an hour and a half into disc
Use a dvd cleaner and then try the movies. Hope this helps.
Dec 21, 2008 | JVC HR-XVC33U DVD Player/VCR
Denon 9000 skips after an hour of use
it sounds like you have a heat problem,try to put your player somewhere that it has alot of room to keep cool,i've noticed some people put there players on top of the t.v. or close to other electronics,the whole key is keeping things cool,let me know if this helps because you have a very good player.
Dec 06, 2008 | Denon DVD-9000 DVD Player
Dvd player skipping
REPLACE SPINDLE MOTOR,IF THAT FAILS REPLACE UR LASER
Jan 01, 2008 | Audio Players & Recorders
Skips to new chapters
I"m also having this problem. Very Annoying
Jan 01, 2008 | Memorex MVD2042 DVD Player
Problem with playing DVD-R discs
The problem is that the mp3 format compresses the files to make them very small. The advance function on the dvd player was set up to advance, let's say, 1/2 second at a time. Well, the dvd or cd file will advance a 1/2 second, but an mp3 format file, which is way smaller, will advance the same distance on the disc which ends up being 10 seconds or so. I had the same problem with my panasonic. Solution would be to burn the files onto the disc in a cd format. You won't be able to put 100+ songs on the disc like you could with an mp3 format, but you will be able to controll the advancing a lot easier.
Oct 18, 2007 | Panasonic CQ-VD7001U Car DVD Player
DVD DMR-E50 Doesn't Work
As it's been 5 months I suspect problem's been solved - how? I have similar problem, E50 recorded DVD-r's lock up after playing about an hour. RAMs and commercial DVDs play fine.
Aug 12, 2007 | Panasonic DMR-E50 DVD Recorder
HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Apr 03, 2007 | Blaupunkt Chicago IVDM-7002 Car DVD Player
Panasonic DVD-CV35 Multi-disc DVD Player Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
