Question about HP LaserJet 4 plus Printer
Manual Feed When trying to print labels on my Laserjet 4 I get the message " MF FEED A4" ,(MF is flashing). Presumably requesting manual feed. Problem is I cannot see where to manually feed the paper. Any ideas welcome. Thanks
    New Friend:
Press the first button on the left bottom side (shift) and meanwile the third button on the left bottom side (continue). And then it should do the job.
Posted on May 10, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
The manual feed door is on the front push and it should release the door, A4 is for Europe, although it will make the copy it will leave  a wide margin on the right. go to hte menu and change the setting to letter.
Posted on Oct 11, 2007
SOURCE:
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
When printing from Word Perfect, the message MF Feed Letter comes up and I have to feed pages manually.
This means you send a printjob that needs "Letter" size and tray 2 is set to another size than "Letter". Make sure you set the papersize on the printer the same as the papersize of the printjob. Gerrit Jan
Oct 25, 2009 | HP LaserJet 4 plus Printer
I have an HP 4V laserjet printer. It was printing fine until today. Both trays are full but it wont print. Form feed light is on, LC load letter message is flashing.
This is looking for Letter Sized Paper and presumably nit A$ that you normally use. This is usually caused by printing US documents and not resetting the paper size in the application before printing as the paper size will be embedded in the document in its original format.
Simply select the whole document and then reset the paper size to A4. You may need to check the document for lost images and tables but generally the text should be OK. Also the index and table of contents will also be affected as you will presumably have more A4 pages in the reformatted document that in the original.
Sep 21, 2009 | HP Office Equipment & Supplies
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Not printing
Please open the manual feed and try to print using manual feed if you are able to print fine using manual feed that check pickup roller of Tray 2.
First of try to print using Manual feed and let me know if it is printing from Manual feed or not.
Jun 30, 2009 | HP LaserJet P2015 Printer
Can't print
It means "manual feed".
Go in to the menu, under paper handling (i think) and turn manual feed "off"
Mar 27, 2009 | HP LaserJet 4 plus Printer
Just tell me how to reset printer into factory settings. I have tried it by LPT1 connection and commands sent from command prompt, but doesn't help. The problem is that printer after print request...
To reset the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 28, 2009 | Zebra LP 2844 Thermal Printer
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Feb 27, 2008 | HP LaserJet 4p Printer
HP LaserJet 4 plus Printer Logo
675 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
