Question about GE 46GW947 46" Rear Projection Television
Need to warm up????
My GE 46GW947 46 in. Rear Projection tv seems to need about 5 minutes to warm up before the picture and sound are good. the screen is static and the dound comes in and out. Is something going wrong inside that I should look at to slove this?
    Genius:
  • 1,694 Answers
Sounds like something wrong in the tuner circuit How about performing a by-pass test? Use the A/V 1 or 2 inputs on the bottom rear of tv to hook-up signal.Use dvd or source box.When the set is cold,turn on and check.If the pix & sound are good,then the tv has a tuner problem. If you can live with two inputs,no repairs need to be done.Caution:observe funky,side-ways hook-up on A/V 2 !!!
Posted on Oct 05, 2007
SOURCE:
Projection television acting like an old picture tube TV.
Yes, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Sep 16, 2009 | Toshiba 43H72 43" Rear Projection...
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
TV needs to warm-up
Check the power setting in the menu. If it's set to low power, switch to standard.
Nov 11, 2007 | Mitsubishi WS-55859 55" Rear Projection...
After 5 minutes of good use screen goes redish color
It certainly sounds like the Red CRT (picture tube) has heater-cathode leakage and is not likely worth repairing, as all 3 tubes usually have to be replaced at the same time for best picture quality.
Feb 10, 2007 | Sony KP-51HW40 51" Rear Projection...
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
On bright screens picture goes to white and shakes
Sounds like a bad crt, also has you set been used to play video games if so this could be a cause for bad crt, weaking tubes
Oct 23, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Red screen
It sounds as though your Picture tubes are getting weak or theres a bad capacitor in the screen drive circuit. The only way to tell would be to call in a tech to diagnose this problem with his test equipment. A tv set is not a place for an unexperienced person to play with. Good Luck
Jul 29, 2006 | Sony KP-41T65 41" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
163 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
