Question about Nikon CoolPix S2 Digital Camera
My flash stopped "flashing"
I have a Canon EOS Rebel XTi and last night the flash just stopped working. I have no idea what to do. I have had the camera since October.
  • 4youk Feb 23, 2008
    i take a shot and no flash everything seems to show its working
    Problem Solver:
  • 9 Answers
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-upMy flash stopped flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Posted on Feb 19, 2008
SOURCE:
Can I use Speedlight SB-50DX with Canon EOS Rebel Xti
It is not possible to use the Nikon SB-50DX directly on a Canon EOS Rebel camera. The Nikon flash gun hot shoe contacts do not match the Canon hot shoe contacts.
You can use the Nikon as a slave flash gun with a PC flash cord that matches the Nikon's flash contacts then connect the end of this flash cord to a flash trigger. The Canon's flash can then trigger the Nikon flash gun via the flash trigger.
Dec 27, 2011 | Nikon Speedlight SB-50DX TTL Flash
I have a canon rebel xti and the flash pops up but doesn't flash even when its dark this is when the setting is in full auto. any ideas? could the "bulb" have broken?
The short answer is yes, that is possible. It's also possible there is a circuitry problem. You will want to verify by trying to use an external flash and making sure it still works. The flash assembly is replaceable if needed.
Thank you.
Mar 08, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon xti and canon 420ex flash giving
Make sure the 420EX is set to E-TTL and set the camera to "P". If is need of more light, increase flash exposure to +1 or 1.5.
Oct 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Only about half the modes work on mode selector dial
Sounds to me like the internal contacts aren't working correctly. Let your local camera store take a look. Hope it's under warranty.
Dec 03, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Nikon CoolPix S2 Digital Camera Logo
105 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
