Question about HP PSC 2410 All-In-One InkJet Printer
Won't power on
I was in the middle of scanning and saving and the printer just shut off by itself. I replugged it in and I get no power whatsoever. I plugged it in another socket in another room and still no power.
  • redlady7 Oct 11, 2007
    Is there a way to fix that?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Sounds like a blown fuse on the power board
Posted on Oct 11, 2007
My scanner on my lexmark x3470 will not scan when i press start it just continues to promt me to press the start button. how am i meant to scan documents?
Try to unplug the power adapter from the printer. Unplug and replug the power cord into the power source. Then replug the power adapter into the printer. This give enough time for the printer to reset itself.
May 31, 2011 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x9575 all in one keeps restarting after slecting scan\copy and fax I have un-installed and re-installed the drivers + reset printer to default factory settings - no change
Try to unplug the power adapter from the printer. Then unplug and replug the power cord into the power outlet. Replug the power adapter into the printer. This will help reset the printer. Check if problem continues.
May 31, 2011 | Lexmark X9575 InkJet Printer
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
My Lexmark all in one won't scan the entire document. No matter what size setting I put it on (I get the 'most' scanned on Automatic, but it is still less than half the page.)
Do you get the same result when making a copy using the Copy button on your printer operator panel? Try to remove the power adapter from the printer.
Wait at least 10 seconds before replugging the power adapter. This will give enough time for the printer to reset itself. When the printer turns on, reinsert the cartridges. Load some paper and try to make a copy or scan again.
May 05, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
My lexmark interact S605 touchscreen is not working properly. It won't display the home screen and has only a small part of the solutions updated showing. When I try to get it to go to main screen it...
Wait at least 10 seconds before replugging the adapter to the printer. This will give enough time for the printer to reset itself. Also, make sure the power cord is plugged in straight to the power outlet in the wall, bypass any power surge devices.
If the problem continues, it could be a faulty power adapter issue. Please contact Lexmark technical support for additonal assistance.
May 05, 2011 | Lexmark Interact S605 All-in-One Color...
Hello, I have a Lexmark x5470 and can not scan at all. When put it on scan, it does say it is downloading and after awhile it says can't retrieve. Clem
If scanning was working perfectly before, it could be a minor communication issue. Unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect it to your computer. Then try scanning again.
Feb 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
Printer wont comunicate with Computer
Try to unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect to your computer. Try to print again. If problem continues, you may refer to these articles in the Lexmark website:
- Communication Not Available' Error Message and Print Job Stalls in Print Queue - No Communications Error When Trying to Print or Scan
I hope these help. Thanks.
Feb 16, 2011 | Lexmark P4350 All-In-One InkJet Printer
When i shut the top and try to print the screen say the top is not shut. is a sensor bad or what
Try to unplug the printer from the power source. Replug after 10 seconds. This will give enough time for the printer to reset itself. If error still shows, you may refer to this article on Error: 'Cover open, please close the cover'. You can also contact Lexmark technical support for additional assistance. Thanks
Jan 12, 2011 | Lexmark X1270 All-In-One InkJet Printer
Getting error code 2200 on Lexmark P6250 Photo All-In-One InkJet Printer. Programme asked to refer to user guide. Error code not in user guide. Unplugged printer while on. Restarted PC then replugged...
hi
here is what i have found -- follow to all instructions accordingly
although its for another model, these isntructions apply according t their techsupport i spoke with
.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
here is where i found the error http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=2200 error#1
hope this helps -- God's speed
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark x6170 random shut off while printing
I think the power saving mode is on your printer ?try setting to off mode or 2 hrs mode...
Mar 13, 2008 | Lexmark X6170 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
22 people viewed this question
Clive
Clive
