Question about Microsoft Office Standard for PC
Double click a cell using VBA - Microsoft Office Standard for PC
  • 27 Answers
This assumes you want to edit the content of that cell: Code: Range("B3").Select SendKeys "{F2}", True Double-Clicking a cell is the same as F2 (edit). Let me know how this works.
Posted on Oct 05, 2007
Remove VBA Password
How to Remove VBA Password - VBA Password Remover Tool to quickly or reliably recover VBA password. This software recover VBA password from your sheet/workbook project password and open MS office files. Source link:- http://www.advance.vbapasswordrecovery.net/
Apr 15, 2013 | Computers & Internet
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
How to dov VBA in ms office 2007
Right Click on the sheet name on the bottom left corner of the excel window and on the pop up menu, click on "View Code". It will open a box where you can perform VBA Coding.
Aug 04, 2009 | Microsoft MS OFFICE 2007 SBE MLK (NA) SW....
Excel vba
For complete guide please refer to this link
http://www.fontstuff.com/VBA/vbatut03.htm
Thanks and regards
Fixya is educating to educate
May 12, 2009 | Microsoft Office Professional Edition 2003...
In Excel trying to compare two ranges
I imagine that the only way is with VBA coding. This is possible if you know programming in Excel (VBA - Visual Basic for Applications).
Apr 17, 2009 | Oracle Database Enterprise Named User Plus
Need Formula
TEXT CASE
Convert to UPPER, Proper or lower
Auto Convert to UPPER, Proper or lower
Stop VBA Being Case Sensitive
SELECT CASE VBA
Select Case Statement. Great alternative to Else If Statements
CONVERSION
VBA: CBool(),CByt(),CCur(),CDate(),CDbl()Double,CDec(),CInt(),CLng(),CSng(),CStr(),CVar().
Example
dDate=cDate("25-Jan-07")
Convert Numbers to Words
Convert Numbers to Dollar Amount in Words
Spreadsheet Converter. Versions: HTML/JavaScript,Excel ASP.Net and Excel Java/JSP. $
SQL Database Migration $
Converters. Database Converters, Spreadsheet Converters, Text Converters, E-mail Conversion, Document Conversion, PDF Conversion and more! $
CSV Converter $
IMPORTING
Import SQL Into Excel-SQL Tester $
Import Excel Into Access $
CONDITIONAL FORMATTING
Conditional Formatting
More Than 3 Conditional Formats
Conditional Format Fonts for greater than 3
CUSTOM FORMATS
Custom Formats
Excel see a cells format as having four Sections. These are, from left to right: Positives;Negatives;Zeros;Text.
To hide zeros cell-by-cell use a Custom Number Format like 0.00;-0.00; where 0.00 is desired format for non zeros. Note the use of -0.00 for negatives.
To hide zeros on the Workbook level go to Tools>Options>View - Zero Values.
Dec 15, 2008 | Microsoft Windows XP Home Edition
Office 2007 Standard - VBA not working
There is no indication that VBA should not work in all versions of Excel. There is a new file extension (xlsm), which is used to activate macros and allow usage. If you have, perhaps, opened and saved with incorrect extension (new is xlsx), VBA may be unavailable. Try to resave it with the changed extension. It seems likely that this is the issue (reference http://office.microsoft.com/en-us/excel/HP100141031033.aspx?pid=CH100648071033). Also, if you make sure your Save As option is set at xlsm, this should help to prevent problems. VBA should not be an issue in any version of Excel and custom functions ARE available (see http://office.microsoft.com/en-us/excel/HA102189961033.aspx?pid=CH100645021033). It should be as simple as changing the extension, and I would suggest changing the default save as option. If this helps, please rate "FixYa"! Thanks!
Apr 03, 2008 | Microsoft Office Standard for PC
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Excel vba password recovery
You can but you will need software. Search for google for VBA password recovery tools. Search for the appropriate crack you have it all . .
Dec 30, 2007 | Microsoft Excel for PC
Microsoft Office Standard for PC Logo
1,267 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
