Question about Acer Aspire RC500 PC Desktop
Blank screen the pc starts as normal but after it shows the configuration then it becomes blank although the led is green of the monitor
Hai pls reconnect the hard disk cables and power cables properly and try again it will work
Posted on Oct 05, 2007
SOURCE:
The monitor suddenly went blank and displayed "no
no signal coming out from the video card input to your monitor. better check if the vga cable is properly fix on the video card and the monitor. you may need also to disconnect the video card from the motherboard and reseat it properly.
just make sure computer is turn off when you do this.
let me know if i can help you further.
Feb 01, 2011 | HP Pavilion a1210n (ED895AA) PC Desktop
Try to pull out video card and clean the slot on motherboard then put video in. If no result replace video card.
Feb 01, 2011 | HP Pavilion 6730 PC Desktop
My dell 4600c monitor will only show a picture when i start or restart it with the monitor power button. it is only on for about 1.5 seconds each time.
If the tower power LED is a Steady Green and the Diagnostic LEDs on the Back are all Green then the monitor itself appears to be the failure point. See if issue occurs with a different monitor. If the tower LEDs are not all green, then reply with the indications
Sep 20, 2010 | Dell Dimension 4600 PC Desktop
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
CRT Monitor power led is green then becomes yellow. The monitor is blank or black. Pls. help.
Signal from Pc is weak and may indficate a failing video card or a loose connection
Aug 02, 2009 | NEC MultiSync FE700M (White) 17" CRT...
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Acer Aspire RC500 PC Desktop Logo
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
