CPU - P4 3ghz prescott, windows XP SP3, GPU - ATI x1950 PRO.
Hi, i have a problem with trying to max my memory out to 3gb. I currently have 2 x 1gb pc3200 ddr (PNY) sticks. All is good but i wanted to add a further 1gb to bring it up to 3gb. My pc will post OK and the mem test is OK but windows won't load ( it gets to the black screen then restarts and sometimes the display is garbled) with my AGP card connected. I can get my pc to load windows with the onboard graphics & the 3 gb mem set to pc2700 in the bios, but as i love cod4 it won't work with the onboard gpu!
Has anyone been able to max out the mem to 3gb running at 400Mhz ?
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
Comments:
May 04, 2009
- you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
