Question about SanDisk Sansa e250 MP3 Player
I can't turn on my Sansa e250!! Help!
Ok, i plugged my mp3 player in the computer to charge up over the night. when i came back and unplugged it safely, it turned off and i tried to turn it back on but it wont cooperate. i've held the button as long as i can, but it still wont turn on. i dont think i have a dead battery though because it turns on when i plug it into the computer. please, someone help me!!
  • 626 Answers
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Posted on Oct 06, 2007
SOURCE:
I shut down the computer while charging my mp3
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
May 06, 2010 | SanDisk Sansa e250 MP3 Player
I connect my sansa e250 into my computer and the mp3 player says connected but i see no sansa hardrive and the computer doesnt respond .
Turn Sansa off. Unplug USB and make sure its clean. Plug back in as normal. If no hardrive comes up go to My Computer and look for it and troubleshoot if necessary.
Finally, repeat this action above accept when you turn MP3 off, hold button for 15 seconds - release and then turn back on.
Nov 05, 2009 | SanDisk Sansa e250 MP3 Player
Disconnected
You need to try hooking this back up to the computer then saftly remove it with the icon on your desktop so it sends a down signal to the unit if that does not work a hard reset is in order.
thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 19, 2009 | SanDisk Sansa e250 MP3 Player
My PC (windows XP) doesn't detect Sansa e250 MP3 player
Turn the player off before you plug it in and if it doesn't find it then turn it on while plug in.
Jul 30, 2009 | SanDisk Sansa e250 MP3 Player
WONT DELETE!!!!
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 won't charge
I had the same problem - the player needs to be unlocked (the little switch on top) to be able to charge - pretty stupid if you ask me but what can you do
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Completely dead
did you try plugging/charging it into your computer?
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa e250 won't charge all the way!! Help me!
Sounds like the battery may have come loose in the back, so its not charging.
Take the 4 screws out, remove the battery. The put the battery back in and try charging it.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 problems
When you unplug your Sansa e250, just turn it back on.
May 29, 2007 | SanDisk Sansa e250 MP3 Player
Sansa MP3 player charges, plays while plugged into wall, but not unplugged.
When you plug it into the wall make sure you turn it off and let it charge all the way before you start using it again. see if that helps
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
