Ive tried 1 1/2 turns on the h and l ajustments still doesnt stay running it runs for a phew seconds then dies i have to start it on full choke till it tries to start then start on half choke
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
This sounds like mine I was told 11/2 on high and 1 on low but it will not stay running unless I keep puming the gas.Do I need to tune it more.Its a dam new pouln pro 50cc 20"
pumping that is I called the dealer and was told to put them all the way in and then back out H 1 1/2 and low 1 still cuts out when given gas
