Question about Kitchen Ranges
Range won't stop beeping
Hi, My range has been beeping since yesterday. I have hit clear/off, switched the breaker to the range off and on and still cannot stop it. The only thing I have done which I think could have caused this is; yesterday I cleaned the instrument panel and also got my shirt stuck on the lever which is for the self clean. Any ideas?
  • janie223a Oct 06, 2007
    Thanks for your response. GE is scheduled to come out Monday morning.
  • 473 Answers
This is something that should be checked by a technician. Could be something simple but when your dealing with 240 volts you need to know what you are doing.
Posted on Oct 06, 2007
SOURCE:
Beeping won stop
Good Morning Gemma - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Is the range still beeping? If so, then the unit may possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. An experienced service technician may need to further evaluate this issue and assist with the repairs.
May 07, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I TRIED TO DO THE SELF CLEAN ON MY GAS RANGE AND IT SAYS F90 AND KEEPS BEEPING, THE LATCH KEEPS CLOSING AND RELEASING OVER AND OVER I TRIED UNPLUGGING, TURNING OFF THE BREAKER AND HITTING CLEAR/OFF WHAT DO...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Whatis F3 mean when sld cleaning oven
F-3 tells you that the electronic control has detected the fault condition.
Press CLEAR/OFF to clear the display and stop any beeping. Then go to the house breaker box and try turning the house breaker to the oven off for 5 minutes. Electric ovens have two switches in the house breaker box. This will reset the system and clear any electronic glitches that are in the system.
If this does not remedy the situation then this means you have a bad oven sensor.
Unfortunately this is not a home handy person fix.
Mar 14, 2010 | LG LRE30755 Electric Kitchen Range
F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Aug 02, 2008 | Amana ACF3325AS Dual Fuel (Electric and...
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Tappan gas range is beeping a code
This is what f 2 means for Tappan:
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor
Nov 15, 2007 | Tappan TGF657 Gas Kitchen Range
Kitchen Ranges Logo
320 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
