Home | Bosch | 24 in. SHU66C05 Stainless Steel Built-in Dis... | Doesn't cycle to ope...
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Problem for Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Doesn't cycle to open soap dispenser
By jbkent99 on May 02, 2009
help?! my shu66 sounds as tho it cycles to some extent- water emties into sink and refills, etc. but the soap dis never empties and the left handed light never flashes to "sanitizer" or beyond- has worked well since 5/04 except for now. thanks, jeff
Solution #1
posted on Jul 20, 2009
Not Rated)
boschrepair
Rank: Master
Rating: 89%, 7 votes
RUN THE TEST PROGRAM TO DO THIS YOU WILL HAVE TO USE BOTH HANDS. Press and hold "Scrub Wash" &
"Delicate/Economy" buttons TOGETHER WHILE HOLDING THE 2 BUTTONS IN HIT THE POWER BUTTON RELEASE THE 2 BUTTONS AND HIT THE 2 BUTTONS AGAIN YOU SHOULD GET A 21 0R 23 CODE AND THE TEST PROGRAM WILL RUN IT WILL TAKE 45 MIN TO RUN BIT WHEN DONE IT WILL SHOW A CODE 1 OR 0 MEANS NOTHING BUT IF YOU GET A NY OTHER # OR LETTER IT CORRESPONDS TO A FAULT
2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
DON
262-893-4840
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU66C05
Questions and Unsolved Problems for Bosch 24 in. SHU66C05
Do you recommend Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher?
Answer
Answer
I found that by initially disconnecting the pipes and cleaning them out (without the usual... (More)
Answer
our bosch dishwasher had some water on the floor . I think it's coming from the bottom seal of the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C05...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
