Question about Motorola Mobility RAZR V3c Cellular Phone
No display totally dark but the keypad is ok when press any of them and the network is ok.
  • 6 more comments
  • supa2007 Nov 20, 2007
    My motorola razr has no display on it's lcd completelt dark but it is functioning well as I can receive and make calls. Any idea what could be wrong with it and how to get it fix.
    thanks
  • Anonymous Dec 05, 2007
    screen went black, keypad lit?
  • Welx Dec 29, 2007
    I googled this site as my phone had fallen in water - no display and I thought it was fried, but I squeezed as directed and it's back. Amazing - thanks!
  • coffeeboy Dec 31, 2007
    I just received a refurbished V3c, I was seeing all sorts of lines and noise on the screen and on the pictures, I tried this trick and WOW!!!!!! IT WORKED AND FIXED IT FOR ME. That was great! THANKS!!!!
  • cynnicole Jun 04, 2008
    Ok.. so I was using my phone and the screen went off... i can make calls.. or receive them but i just cant see who is calling and I have tried the whole pressing on my screen beside the volume but it did not help.. and I can get a new phone thats not the problem its just all of the phone numbers are saved to my phone not my sims card or memory card so I dont know if there is anyway to get all of those numbers off of my phone but I sure hope so if anyone knows a way to do anything to my phone PLEASE help me I need it in the worst way thank you so much...
  • runnerguy525 Jun 06, 2008
    I am having a very similar problem, however I have a motorola slvr.  Any advice would be great.  I already opened up the battery and checked the white thing for moisture.
  • pcnet Jan 02, 2009
    power to razr blue bluetooth light showing screen completely dark but when apply pressure to this can see everything that shows me phone working.
  • sunisankara Feb 03, 2009
    Same issue. My razr v3 is functioning normally, but no display. I do get the display some days, but after a few days of normal functionality, it goes dark again. This last time it also beeped before it went dark
  • 10 Answers
Open phone then with camera lens facing you squeeze area between camera
lens and vol up/down buttons.  This reseats the ribbon cable located under
the cover.  It becomes loose with all the opening and closing of the phone.
Posted on Oct 11, 2007
  • GEngineering Dec 03, 2007
    Turn phone off then remove battery. There is "DOT" where the battery compartment is. It should be white. If it is a color other than white the phone was exposed to moisture. If this is the case you will have to purchase a new phone. Sorry. Let me know.
Not working!
Posted on Nov 09, 2008
I googled this site and found the solution. Oh my GOD the trick worked...thank you GE engineering. I thought I needed to buy a new phone. This is amazing, I squeezed the back and my light came back on...the phone is 3 yrs old and still working...
Posted on Jun 16, 2008
I have a V551 and was fishing around for the solution to my black screen. My phone had fallen from my bedside stand to the floor last night and though it worked normally, the light on the screen wouldn't come on. So I read GEngineering's solution and I wondered: "squeeze" the phone??? But I decided to try it and it worked! I applied a bit of pressure on the 'outskirts; of the screen itself. The light came back on and my phone is now working great! I love this phone so much and have used it for almost 3 years (no one understands why!).
Thank you, GEngineering!
Posted on Nov 26, 2007
2 Suggested Answers
SOURCE:
solutionzone
  • 86 Answers
SOURCE: no display
The display was dameage so you can go to the mobile hardware point and they will solve.
Posted on Mar 06, 2009
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
I can't get my Macbook setup to use the Lexmark x6650. I used the install disc and the wifi light on the printer is green, but I still cannot figure out how to setup my Macbook to print to is...
Print the network settings page to identify if your printer is connected to your wireless network:
1. Press Setup on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address. SSID should be the name of your wireless network. Otherwise, you may need to reset the printer's wireless network settings.
How to reset network settings:
1. Press Setup.
3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, press OK.
4. Press the right or left arrow button to display Yes, pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark Wireless Setup Assistant on your Mac.
Sep 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My phone dect 6.0 uniden rings when someone calls but will not dial out
Hello :
Maybe you need to program the phone .
Here I'll tell you how :
  1. Press the Down main navigation button and press Menu/OK. The main navigation button is in the center of the keypad and is cylindrical in shape.
  2. Press either the Up or Down main navigation button until "New Entry" appears on the display.
  3. Press the Menu/OK button and "Enter Name" will appear on the display.
  4. Enter the name using the keypad. Enter the names the same way you would enter text in a text message on a mobile phone. For example, to enter the character "H," press the 4 digit twice. Use the labeling on the buttons to guide you.
  5. Press the Menu/OK button after entering the name and "Enter Number" will appear on the display. Enter the phone number using the keypad.
  6. Press the Up or Down navigation button to select "Save" or "Go Back" and then press Menu/OK. The entry is now programmed. Press the goodbye button; it's the button with the phone icon on a cradle.
  7. Press the Down navigation button and the first alphabetical number is displayed. If you keep holding the button, the phone will scroll through your phone book alphabetically.
  8. Press the button with the phone icon on it (not the goodbye button) to dial the number associated with the phone book entry.
I hope that will help .
rate if useful please !
Feb 22, 2010 | Uniden DECT 6.0 Cordless Telephone...
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
No display totally dark but the keypad is ok when press any of them and the network is ok. NO DISPLAY
Mar 06, 2009 | Cell Phones
F-6 showed up on my microwave window
self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "?" is displayed...
F6 ?Microwave Relay Failure: Check the microwave relay.
Jan 26, 2009 | Whirlpool MH7140XF Microwave Oven
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
IN 120 base keeps flashing CL
- press the OK key
Jul 09, 2008 | Lands Phones
There is a big trouble
all faxes use automatic fallback sytem for dropping the speed as well as the machines communicate on the highest common speed therefor you don't need to set the speed. Apart from the situation if your phone line is disturbed and not receiving faxes and giving communication errors.... happy faxing omnipresent
Nov 08, 2006 | Xerox FaxCentre F110 Plain Paper Laser
Motorola Mobility RAZR V3c Cellular Phone Logo
1,517 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
