Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Poor recieve walkabout 250 (6-7 years old) no longer recieve when the 2nd one is transmitting unless the listening set has the montior button depressed (even then, only poorly/inconsistently). (has fresh batteries, tried/tested both on several sets of matching frequencies, done at ranges of 5 to 25 feet, all with same negative results). Adjusting volume knob does not activate/adjust squelch (anymore?). I seem to remember that I used to keep them on mild background static level to ensure incoming calls caught...doesn't seem to wrok that way anymore.
    Problem Solver:
  • 20 Answers
Another thing it might be is just basicially a bad antenna conection. Alot of these antennas cannot be removed on these radios since it illegal to use a bigger external antenna . The manufacturers make them "not removable".... well you can just unscrew them. It could be an antenna problem.If you want to check into, go ahead.... but these are just FRS radios and for the most part are disposable. It might be easier to just grab a new set.
Posted on Oct 05, 2007
  • 123 Answers
It sound like one of this radios is out of frequency, basically need service to determ what exactly is wrong. When one of the radios is out of freq, basically mean that the radio is not receiving or transmitting where suppose to.
I have a galaxy 73v that transmits on oe channel recieves on another
common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
Aug 21, 2012 | Galaxy Radios DX-73V 40-Channels Base CB...
Can you make a baby monitor out of the Motorola 250 model
hello yes you can use these as baby monitors .set one with vox on turn its volume down completly set the channel you require ,secondly the receiver radio set to same channel and that is it though i should state that these radios transmit on pmr band 446 mhz which is widely in use by many people nationwide so they can also listen in to whats been transmitted from your home not very private im afraid !! I would suggest you purchase a wired system hence more privacy and peace of mind hope this helps you
Nov 24, 2011 | Motorola Talkabout FRS 250 (14 Channels)...
My walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola...
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
I have a one year old Raymarine 218 vhf which has been transmitting properly however the receiving has been spotty. I can sometimes only get about 1 mile reception. Lately even the one mile reception has a...
The main cause for lack of reception or transmit distance is the PL259 connector on the antenna coax that plugs into the back of the VHF. Check to make sure this connector is a high quality, marine grade connector. If it screws on and the coax shield is not soldered to the connector I recommend replacing the connector and soldering it. If the problem still exists I would try a different antenna to see if this is the problem. It is possible that the radio itself has a problem, but check these other issues first. Raymarine has a 3 year warranty on their VHFs so you could send it back for a no charge repair if the antenna doesn't solve your problem.
Jun 13, 2010 | Raymarine Ray218 Vhf Radio
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Apr 29, 2010 | Onkyo TX-DS575 Receiver
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Cb on 1994Goldwing doesn't work.
Just off the top of my head, It sounds like a bad microphone connection. When you press the transmit button on the mike. it is supposed to shut off your recieve while you talk, so you dont feed back through the speakers. From what you write it sounds like the recieve is being shut down, but your voice isnt getting through. I would try a differnt mike, or if you are handy try taking the connector off the mike apart and look for a broke or loose connection.
Jan 31, 2009 | 2003 Honda GL 1800 Gold Wing
Cobra 148 gtl
Open the radio up and find the L22 Can/Pot. It's the one with the wire soldered on top. With both fine and coarse Claifier/Voice Locks in the 12 O'Clock positions, confirm, then listen for someone that is on the correct frequency and turn this pot (small ferrite core inside) with a small plastic preferred screwdriver, until they sound clear. Do this for USB as well except, the Can/Pot is L59. Don't adjust the VR5 (transmit) unless you need to.
Oct 06, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Roady XT Transmitter problem
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
Jul 02, 2007 | Delphi Roady XT XM Radio Receiver
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
103 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
