Question about Sony DVP-NS305 DVD Player
Not closing I was playing a DVD and when I cam to eject the disc the disc was not there, as it had came ot of the tray and got stuck in the player, I managed to get the disc out but now the tray willnot close more than halfway, is there anyway of repairing this without spending too much money?
  • 4 Answers
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Posted on Oct 08, 2007
  • Anonymous Oct 08, 2007
    Sorry about this, but in my latest solution, there are a few typing errors.
    1.In the time being, open the layer's- layer's=player's
    2.The only way thate one can fix...-thete=that.
    3.Ttopping the tray from opening.-opening= opening/closing.
    Thank-you!
SOURCE:
I have a new samsung bd-f5700 player and tray won't open. Tried using the remote to open & the panel on top of player to open. Nothing works.
First, try resetting your player. Unplug it from wall for at least 1 full minute, then plug it back in. If eject function (remote or top panel) still doesn't work:
MOST DVD players (including every one I have ever worked on or owned) have a tiny manual eject pinhole located close to the tray. You may have to gently open the flip door to see it. It is usually to the right of the disc slot, but could be underneath or elsewhere close by (use a flashlight, it can be hard to see). Carefully insert a straightened paper clip in the pinhole to eject the disc. (It shouldn't matter if machine is on, but for safety I usually do this with the machine OFF and unplugged).
see http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html
or
http://www.ehow.com/how_2036594_fix-dvd-player.html
and http://www.ehow.com/how_6330619_retrieve-jammed-cd-dvd-player.html
If above fails, your only recourse is likely the disassembly of the machine (search "dvd disc stuck" on Google or YouTube), or taking your machine to a repair person. Best of luck to you.
Jun 23, 2014 | Samsung BD-F5700 Blu-ray Player
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My dvd tray is stuck...I think it's a dvd stuck in the tray
unplug the player for 5-10 min...once you plug it back and power on quickly tap the open/close button (the player by default will try to load the disc)
feel free to rate help
Jun 26, 2010 | Yamaha DVD-C996 DVD Player
Dvd stuck in machine will not play or open to remove movie
there might be something hooking the disc tray that is prevent it from opening.
The solution to this problem now is to, get a screw driver, unscrew the screws on the player, open the player cover so that you can gain access to the disc stuck inside, remove the disc and check for what's preventing the player from ejecting.
Take care.
May 30, 2010 | Panasonic DVD-S35 DVD Player
The dvd drawer on my BD-HP16U is stuck in closed position. The screen display "hold" when I push the eject button.
Try inserting a small pin through the hole beneath the insertion cabin, after pressing the eject button. If you don't have such a hole, Push the eject button and tap hardly on the top of the player. The drive will come out in two or three attempts.
Apr 13, 2010 | Sharp AQUOS Blu-ray Disc Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Sony DVP-NS305 DVD Player Logo
243 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
