Question about HP Photosmart 3210 Printer
Out of paper:
Load paper in main tray for hp photosmart 3210
  • 3 more comments
  • njanja Oct 05, 2007
    can someone advise me on how to solve this out of paper problem for my hp photosmart 3210 printer.Even when the paper tray is loaded it still reports out of paper,load paper in main tray.
  • Anonymous Nov 01, 2007
    HP printer will not pick up photo paper, sends out of paper message
  • lrbdle Nov 22, 2007
    same problem here!
  • Anonymous Nov 22, 2007
    Same problem as others, lists "load paper in Main Tray" even though tray is full. Tried the calibration technique noted on this thread and it didn't work either.
  • frotterus Jan 09, 2009
    Same problem. Contacted HP support, but their ultimate solution was to pay for a special tray that, I believe, scuffs the rubber pickup rollers. I refuse to pay extra for an obvious design flaw. I've ended my patronage of HP products.
I have the same problem. HP support suggested calibrating the media sensor. Here are the steps they provided to me. It didn't work for me, but it may work for you. 1. Press Left arrow and Right arrow simultaneously on the front panel of All-in-One. 2. Press 3,2,9 on the front panel of All-in-One. 3. Press Left Arrow. 4. Press Ok. 5. Press Left arrow. 6. Press Ok.
Posted on Oct 08, 2007
I unplugged the printer and took the back cover off and cleaned all rollers using rubbing alcohol and q-tips. I also used canned dust remover and sprayed all parts. This took care of the no paper in tray issue for me!
Posted on Apr 07, 2008
I had this issue and HP said it was a major issue with the printer. I ended up getting it replaced.
Posted on Nov 10, 2007
2 Suggested Answers
SOURCE:
  • 346 Answers
SOURCE: Can't Print
HP Paper Feed Cleaning Kit - Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754199&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
ou may not have the paper width set snug to the paper to feed correctly.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553862&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
Consult http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601439&cc=us&lc=en&dlc=en&product=439488 regarding "out of paper" errors Paper cleaning kit is included in this article.
Posted on Apr 19, 2008
I have a HP Photosmart 3210. There is a paper jam. How do I get the paper tray out to get at the jam
You can follow the step by step procedure from HP site to clear the Paper jam on this printer, just go to this link and from there follow the procedure. click HERE.
Nov 07, 2010 | HP Photosmart 3210 Printer
I have a hp photosmart 3210 all-in-one and i cant figure out where the paper goes
For problems like this you can always refer to the manual. If you do not have the manual it can easily be found on HP's website under their support section.
The paper loads in a small tray in the front of the machine, underneath where the printed paper exits.
Jan 15, 2010 | HP Photosmart 3210 Printer
I have a MAC OS 10.4.11 and an HP Photosmart 3210 all in one. I use Iphoto and have been trying to print a 4 x 6 photo from Iphoto directly to printer. No matter what I try the photo tray does not engage...
I haven't been able to make it work from photo tray either but I do put photo paper in main tray and change settings in Iphoto accordingly and print pics that way.
Oct 02, 2009 | HP Photosmart 3210 Printer
Paper Jam, when there isn't a paper jam!
just remove thr paper outer tray and see if there is any part of paper is there.
Sep 08, 2009 | HP Photosmart 3210 Printer
Manually feeding paper
Even if manual feeding is an option the paper must be able to fit the paper tray in order to feed it through the printer.
Jan 20, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210xi All in one printer will not print 4x6 photos
Have you processed many print jobs through this printer? if so, you might be needed a maintenance kit. the kit will include new rollers that will help pull the paper into the proper feed paths.
Apr 30, 2008 | HP Photosmart 3210 Printer
Can't Print
Apr 19, 2008 | HP Photosmart 3210 Printer
Paper feed problem
Check all this-----
1.check the printer paper feed roller jam.
2.check the paper sensor, It is working or not.
3.check the paper tray(clean it)
4.service the printer, (If possible).
Goodluck
Mar 10, 2008 | HP Photosmart 3210 Printer
Paper won't load up....
Disconnect the printer from power source and computer. Remove the rear access panel and very carefully use a alcohol moistened cotton swab to clean the all the black rubber pick-up rollers. Use a gentle sideways stroke while cleaning and turn rollers to clean all sides. Allow the rollers to dry and replace the rear cover and power up. Worked wonders for me. HP has certain 3210 printers that have this problem.
Oct 25, 2007 | HP Photosmart 3210 Printer
Clicking Noise
Go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587637&lc=en&cc=us&dlc=en&product=439488&rule=44236&lang=en and I think you'll find what you need to solve the problem. often this type of error is caused by trying to clear a paper jam by pulling it out the wrong way, one or two of the gears slip and everything gets out of sync. If you can't solve your problem with the HP troubleshooter, please ask again and I can try and talk you through the resetting process. Hope this helps:)
Feb 27, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
411 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
