Question about Sony KP-61V85 61" Rear Projection Television
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
Can someone please help!!!my remote was lost in chair i was digging for it ithink a button was pushed and picture went off still had sound then i turned power off. now when i plug in to power only a red lite on panel saying timer stand by stays lit but nothing happens. is the a timer and can i reset some how?please please help i am disabled and cant afford repair bill cant trust repaicompany in my town it could be my stupidity and they will try to charge big bucks for nothing major.i do not have any manuals as i bought it used last month.out of newspaper.SONY KP-61V85 61" PROJECTION TELEVISION
    New Friend:
I have the same problem, can you tell me if yours is fixed yet please. Id like to add that when u plug it in it powers on and timer light comes on but none of the buttons on the front of the tv work unless the picture and sound comes back, which i find if you leave it plugged in long enough happens. I was able to use the this way for a few days, but now dosent work at all.
Posted on Aug 06, 2013
    Genius:
  • 1,153 Answers
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Posted on Oct 05, 2007
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
Good sound no picture
A older set------look to see if display comes on (channel number or menu) if not someone has to look to see if the filaments in the three picture tubes are lit or not.
Several voltages : High voltage, screen voltage, filament voltage all go to the picture tubes.
Oct 30, 2012 | Sony KP-61V75 61" Rear Projection...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Black screen and red timer light is on
It may be the problem of the Dish connection or stablizer. Remove the stablizer and connect the Tv direct to switch board and re connect the dish connection. Then switch on the TV it will work.
Nov 04, 2008 | Samsung HCM4215W 42" Rear Projection...
When t.v. is turned on, black picture and no sound.
Usually when the fuse blows its due to a component being shorted and if you increase the rating of the fuse you can cause other components in the circuit to blow. The pop you hear was most like a capacitor on the D board. The D board is no longer available from sony as its listed as discontinued. You will most likely have to have a qualified sony service tech trouble shoot the circuits on the D board to locate the short as it will be outside the scope of a do it yourself type of repair
May 16, 2008 | Sony KP-61HS10 61" Rear Projection...
Just a click when plugged in and steady red lite??no flashing or pic or sound
If you are a qualified technician then you can try removing the flyback transformer FBT and have it check thru a flyback checker from any electronic repair shop. You will be able to confirm whether you have a problem in the high voltage section. Which would likely is the case. If FBT is OK look for a shortgae in the horizontal section specially the horizontal output transistor. good luck
Oct 15, 2007 | Sony KP-61V85 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
